11-19-2015, 04:27 AM
#21
Mantua
, Ohio
If you have hookups check the breakers. You probably do not. Here's a case for a generater and electric heaters to be used for emergency backup. Hope it is a simple solution, good luck.
11-19-2015, 08:34 AM
#22
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
No hookups out here, I have a generator, but I'm in a developed campground in the Mojave. No space heaters. We were fine last night. I have reflectix cut for all the windows.
We're heading to Yuma on Saturday.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
11-19-2015, 07:31 PM
#23
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Safe travels to Yuma, you will likely meet some forum folks there. It's an interesting conglomeration of people out in the desert. Have fun.
Hittenstiehl
11-19-2015, 07:49 PM
#24
2023 25' Globetrotter
Manheim
, Pennsylvania
I had the exact same issue recently. The one tank did not have enough gas pressure to run the furnace, near empty I guess, when I switched to the other tank it did eventually start. This took a couple of attempts. I think the furnace needs good pressure to run.
11-28-2015, 10:58 AM
#25
Nomadic
, USA
Fixed it. Just some loose connections I guess. I used my air gun and blew all the dust build up out of it, used electrical spray on the contacts to clean them and then hit the rest switch again, and she fired right up. So. Knock on wood, hope that lasts.
11-28-2015, 12:33 PM
#26
1987 Avion 34W owner
Good Ol'
, USA
Glad to hear you got it fixed!
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
I this great country!!!!
1987 Avion 34W
11-28-2015, 03:33 PM
#27
Mantua
, Ohio
Very resourceful, good for you, now get warm and get camping.
11-29-2015, 07:25 AM
#28
2015 25' International
Scottsdale
How much will the heater warm a trailer? On a recent trip is was 22 degrees outside and the trailer only got to 44, is this normal?
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
11-29-2015, 08:09 AM
#29
Good Ol'
, USA
I'm fighting a problem on our house gas furnace. Every once in awhile, the furnace will run but no heat. Indicator on the control board indicates a problem in the "high limit" circuit. Those two sensors are good, confirmed with trusty meter. Reseated the connections at each sensor, still had the problem. Unplugged/plugged the 12-pin connector at the control board, then it works fine. Next step will be to meter the limit switch loop from that connector, and check the control board connector pins for cold solder joints.
PaulnGina
1987 Avion 34W
1987 Avion 34W
11-29-2015, 09:11 AM
#30
1993 34' Excella
Estancia
, New Mexico
In a word, no.
11-29-2015, 08:05 PM
#31
1986 34' Limited
1975 27' Overlander
1969 21' Globetrotter
Conifer
Good job Bold Adventure. Gotta keep the family warm at night. I had a new Suburban NT-30 furnace quit on me. I could not find the problem. I removed the furnace and hauled it to a RV tech. They diagnosed a bad circuit board. A hundred bucks later I was warm again.
Bad luck a loose connection happens the same time the unit runs out of gas. A real curve ball, wouldn't be what I would expect.
David
11-30-2015, 09:42 AM
#32
Nomadic
, USA
I'm going to order a spare blower motor just to have on hand incase.
