Old 11-29-2015, 08:09 AM   #29
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I'm fighting a problem on our house gas furnace. Every once in awhile, the furnace will run but no heat. Indicator on the control board indicates a problem in the "high limit" circuit. Those two sensors are good, confirmed with trusty meter. Reseated the connections at each sensor, still had the problem. Unplugged/plugged the 12-pin connector at the control board, then it works fine. Next step will be to meter the limit switch loop from that connector, and check the control board connector pins for cold solder joints.
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 11-29-2015, 09:11 AM   #30
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Originally Posted by Ponyfvr View Post
How much will the heater warm a trailer? On a recent trip is was 22 degrees outside and the trailer only got to 44, is this normal?
In a word, no.
Old 11-29-2015, 08:05 PM   #31
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Good job Bold Adventure. Gotta keep the family warm at night. I had a new Suburban NT-30 furnace quit on me. I could not find the problem. I removed the furnace and hauled it to a RV tech. They diagnosed a bad circuit board. A hundred bucks later I was warm again.
Bad luck a loose connection happens the same time the unit runs out of gas. A real curve ball, wouldn't be what I would expect.
David
Old 11-30-2015, 09:42 AM   #32
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
I'm going to order a spare blower motor just to have on hand incase.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Burner and Blower Won't Start For Furnace heyhello Furnaces, Heaters, Fireplaces & Air Conditioning 14 05-31-2015 04:59 PM
Furnace Won't Fire/ Start jnerges Furnaces, Heaters, Fireplaces & Air Conditioning 47 03-02-2014 05:59 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
Furnace Won't Start perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 27 10-14-2012 12:40 PM
Hydro Flame furnace blower quit working won't start nsteel Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-04-2010 03:27 PM
