Old 11-18-2015, 12:56 PM   #15
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Originally Posted by cwf View Post
Is there air moving? Did an Umpa-lumpa's thumpa get stuck in the return air vent???
There is nothing happening with unit. Nothing got sucked in.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 11-18-2015, 01:02 PM   #16
2016 30' Classic
Erie , Colorado
If the fan does not run at all then likely the motor has failed. Without the spinning fan which in turn closes the contact on the 'sail' switch nothing else is going to happen.
Can you turn the fan squirrel cage by hand? Be careful, it usually rotates clockwise. Maybe something got jammed. Turning it the other way may catch and bend the sail switch.
Easy to remove the sail switch on most of the Atwood furnaces. If you have a multimeter you could remove it and simply check that when the sail pushes in on the contact that you electric flow.
Gary
2015 Classic
2015 GMC Sierra 2500HD Duramax
ProPride
NVPN
ghaynes755 is offline   Reply With Quote
Old 11-18-2015, 01:05 PM   #17
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
In freezing weather and a fuel-powered device quits one of the first things we look for is something icing up, often a fuel supply line or components. Possibly something in the air supply. I don't know what your overnight temps were or if it's warm enough during the day to thaw if this was the case?
Doug and Cheryl
Old 11-18-2015, 01:07 PM   #18
2016 30' Classic
Erie , Colorado
Found this for you. Your model appears to have the sail switch buried on the back side. See if this link is of any use My Atwood 8525 IV DCLP tries to start. Blower motor runs,
Gary
2015 Classic
ProPride
NVPN
Old 11-18-2015, 07:37 PM   #19
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Furnace won't start
In order for the sail switch to close and allow the gas valve to open the blower must be running. The furnace starts by running the blower for a period of time to purge the plenum.
The sail switch will close if it is functioning properly when the air flow is sufficient. The sail switch will send a signal (voltage) to the board. If the high limit temp switch is made, which means it is not over temp. The igniter will come on and the gas valve will open. The flame rod will signal the board that flame has been established.
Again! If the blower is not running you need to find out why. The sail switch is located in the plenum not in the blower housing.
TG Twinkie is online now   Reply With Quote
Old 11-19-2015, 04:13 AM   #20
1999 30' Excella 1000
small town , Maryland
Head south my friend, colder weather ahead.
streaminwild is offline   Reply With Quote
Old 11-19-2015, 04:27 AM   #21
Gainesville , Florida
If you have hookups check the breakers. You probably do not. Here's a case for a generater and electric heaters to be used for emergency backup. Hope it is a simple solution, good luck.
Old 11-19-2015, 08:34 AM   #22
Nomadic , USA
No hookups out here, I have a generator, but I'm in a developed campground in the Mojave. No space heaters. We were fine last night. I have reflectix cut for all the windows.
We're heading to Yuma on Saturday.
Old 11-19-2015, 07:31 PM   #23
Hittenstiehl's Avatar
1961 28' Ambassador
1961 19' Globetrotter
Mesa , Arizona
Safe travels to Yuma, you will likely meet some forum folks there. It's an interesting conglomeration of people out in the desert. Have fun.
Hittenstiehl
Hittenstiehl is offline   Reply With Quote
Old 11-19-2015, 07:49 PM   #24
Manheim , Pennsylvania
I had the exact same issue recently. The one tank did not have enough gas pressure to run the furnace, near empty I guess, when I switched to the other tank it did eventually start. This took a couple of attempts. I think the furnace needs good pressure to run.
Jukeboxfun is offline   Reply With Quote
Old 11-28-2015, 10:58 AM   #25
Nomadic , USA
Fixed it. Just some loose connections I guess. I used my air gun and blew all the dust build up out of it, used electrical spray on the contacts to clean them and then hit the rest switch again, and she fired right up. So. Knock on wood, hope that lasts.
Old 11-28-2015, 12:33 PM   #26
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Glad to hear you got it fixed!
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Whats good for me may not be good for the weak minded.
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 11-28-2015, 03:33 PM   #27
Very resourceful, good for you, now get warm and get camping.
Old 11-29-2015, 07:25 AM   #28
Ponyfvr's Avatar
2015 25' International
Scottsdale , Arizona
Wink
How much will the heater warm a trailer? On a recent trip is was 22 degrees outside and the trailer only got to 44, is this normal?
2017 Ford F-250 Diesel
WBCCI # 5462 4CU
Ponyfvr is offline   Reply With Quote
Burner and Blower Won't Start For Furnace heyhello Furnaces, Heaters, Fireplaces & Air Conditioning 14 05-31-2015 04:59 PM
Furnace Won't Fire/ Start jnerges Furnaces, Heaters, Fireplaces & Air Conditioning 47 03-02-2014 05:59 PM
My RV will start using the Aux Start but not with the chassis battery mcm9970 Land Yacht/Legacy Motorhomes 7 05-19-2013 07:47 PM
Furnace Won't Start perryg114 Furnaces, Heaters, Fireplaces & Air Conditioning 27 10-14-2012 12:40 PM
Hydro Flame furnace blower quit working won't start nsteel Furnaces, Heaters, Fireplaces & Air Conditioning 3 01-04-2010 03:27 PM
