10-13-2009, 07:38 AM
1976 Argosy 26
G.H.
, Michigan
Furnace won't blow hot with 12V lights on.
I have a weird problem with my 76 Argosy. If I turn my overhead lights (any of them) on when the furnace is running the fan slows down and it starts to blow cold. If I turn the lights off the furnace works great.
Any ideas?
10-13-2009, 07:50 AM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
The furnace fan slowing down when you turn on a 12 volt lamp is probably an indicator of a bad coach battery or a problem with the converter. I would first try taking another 12 volt battery (like from another vehicle) and see if you have the same problem.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
10-13-2009, 07:51 AM
1972 31' Sovereign
Lexington
Are you plugged into shore power, or running off batteries? Sounds like a low battery condition.
And wecome to the forums! Is G.H. Grand Haven by any chance?
Chris
10-13-2009, 07:54 AM
2002 25' Safari
Dewey
The fan needs to operate fast enough to activate the sail switch. Your battery is getting low.
Richard
10-13-2009, 08:03 AM
1975 Argosy 24
Malakoff
Look for loose connections BEHIND the fuses in the
converter before ya get another battery. I found
loose connections causing problems...dimming/flicker.
The converter takes alot of vibration. Turn everything on
and wiggle the fuses....look for sparks and dimming
when wiggling the fuse.
10-13-2009, 09:57 AM
Elkhart
, Indiana
Dust balls or fur balls from a PO's pet may be stuck on the sail switch. With the decreased fan speed it may not be making good contact. Try using an air compressor to blow the furnace clean. It worked for our 72.
Mike
Have a great day!
TAC # IN 1 Air#27922
10-14-2009, 07:25 AM
1976 Argosy 26
G.H.
, Michigan
I am plugged into shore power so I assume I should be looking at the converter. Thanks for the ideas and yes GH is Grand haven.
10-14-2009, 07:35 PM
1972 31' Sovereign
Lexington
Originally Posted by sbroemer
... yes GH is Grand haven.
Cool! I grew up in Grand Haven, and Kay is from Spring Lake! After my 6 year tour in the Navy, we ended up settling in Minneapolis because that's where I found a decent job. We still have family in Spring Lake and Grand Rapids, and make at least two trips there every year.
Chris
10-13-2014, 08:51 AM
Livingston
How long has it been since you checked the battery water level? Depending on how everything is set up, if your battery is not accepting a charge it could be your problem.. basic rule of trouble shooting, start with the simple fix first and move up.. battery water level should be simple to check. MHO
