Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-16-2007, 02:27 PM   #1
Lochsa
Profile:  2007 23' International CCD
Corbett , Oregon
Furnace / Winterizing
I'm a new owner of a 2007 International AS & had it winterized for the first time---tried to warm it up today, but no heat. Proceeding on the basis that the only stupid question is the one not asked: Does winterizing prevent the furnace from producing heat? If so, can I 'override' that some way?
Still learning---thanks.
Lochsa
Lochsa is offline   Reply With Quote
Old 12-16-2007, 02:38 PM   #2
2airishuman
2airishuman's Avatar
Profile:
hi lochsa
not many stupid questions here, just stupid replies!
and here's one...
did you turn ON the lp gas at the tank valve?
even IF the gas is on at the tank the lines may be empty,
the furnace isn't affected by winterizing but it may not ignite IF there is air in the lpgas line.
so turn on the tanks and light the range burners briefly.
the furnace will now need to be shut OFF completely (turn the thermostat OFF) for a few minutes to reset.
turn the thermostat back on, then try the furnace again.
the ignitor should work now, with hot air blowing soon after ignition.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 12-16-2007, 02:47 PM   #3
Lochsa
Corbett , Oregon
Thanks---will do!
Lochsa
Old 12-16-2007, 02:59 PM   #4
Lochsa
Corbett , Oregon
2airishuman-
Success---thanks very much!!!
Lochsa
winterizing transplant Winterizing, Storage, Carports & Covers 16 12-09-2007 09:03 AM
De-winterizing frozen chosen Winterizing, Storage, Carports & Covers 9 12-06-2007 08:14 PM
winterizing twall7 Winter Living 4 09-22-2007 03:24 PM
Help with de-winterizing chuman70 Fresh Water Systems 2 06-14-2007 09:59 AM
De-winterizing snpotratz Fresh Water Systems 7 03-19-2007 01:48 PM
test
