Old 08-11-2003, 09:11 AM   #1
Send a message via Yahoo to Siddiqir
Furnace Water Leak when AC is on
My GE furnace has a water leak. This is only occuring when the air conditioner in running. The nearby carpet is soaked.
How do I stop this leaking. Please advise
Siddiqir is offline   Reply With Quote
Old 08-11-2003, 09:22 AM   #2
mkeith54's Avatar
1976 26' Argosy 26
New Florence , Missouri
Send a message via AIM to mkeith54 Send a message via Yahoo to mkeith54
Leak
I'll bet it's not the furnace. The A/C has a drain tube the drains the condensate down through the walls and dumps it on the ground. That line may be plugged up at the bottom, disconnected at the top or cut some where inbetween. I would start by checking this line.
Mike Keith
75 Argosy 26'
96 Ford F-250 PowerStroke
mkeith54 is offline   Reply With Quote
Old 08-11-2003, 09:27 AM   #3
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
More info
Please fill out your profile so that we know what sort of RV you are having trouble with and can give a more complete answer.
A short answer is that there is no water associated with the furnace; the only water that has any connection to the AC running is the condensation from the coils which is normally carried away by a 1/2" tube to under the unit or simply dumped on the roof to run off the side.
I suspect that the over flow tube from your AC is plugged, kinked, disconnected, ot otherwise disabled. The furnace is just where the water happens to appear.
John W. Irwin
WBCCI #9632
Old 08-11-2003, 09:27 AM   #4
I am bit confused because the out door AC unit is really far away from furnace? So in other words the pipe between furnace and outdoor unit has a problem. Thanks in advance
Old 08-11-2003, 12:40 PM   #5
mkeith54's Avatar
1976 26' Argosy 26
What type of uint do you have? Is it a trailer or a motorhome? Also, what year and size.
The Condensate hose on some of the trailers runs down from the A/C unit between the inside and outside skin and exits at the bottom of the trailer.
Another way the water could wind up by the heater is if the condensate is dumped on the roof, then the water should run off the trailer to the ground. But, if a seam on the roof is not sealed well than the water might get between the walls and migrate to the heater. It is probably comming out in that area because there is a hole in both walls where the heater is installed or the vent for the exhaust is.
Mike Keith
75 Argosy 26'
Old 08-11-2003, 01:05 PM   #6
I found this website while searching the net. The first diagram shows exactly what I have
http://www.statefarm.com/consumer/vh...es/aircond.htm
I guess "condensate drain line" is blocked as you guys suggested above. I will check it when I get home
The article is very well written as I did find many others article but after reading them there were still ????
One question I have if it turn out that there is no problem with "condensate drain lines" then what should I look next?
Please advise.
Old 08-11-2003, 01:29 PM   #7
gwsullivan's Avatar
Well I'm confused? Is the furnace in a house, TT or MH???
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 08-11-2003, 04:03 PM   #8
Yes it is.
Old 08-11-2003, 04:08 PM   #9
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
Question Oh, well in that case....
Old 08-11-2003, 08:43 PM   #10
Pahaska's Avatar
Hays County , Texas
Originally posted by Siddiqir
Yes it is.
Should we flip a coin?
Please specify the year and model of the unit that you have the problem with.
John W. Irwin
WBCCI #9632
Old 08-11-2003, 09:14 PM   #11
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Talking
Yes it is.
Oh Oh...I'm seeing an Abbot and Costello thing starting!
Now let's see. We have on the bags - we have Who's on first, What's on second, I Don't Know's on third.
Costello: That's what I wanna find out.
Abbott: I say Who's on first, What's on second, I Don't Know's on third -
Costello: You know the fellows' names?
Abbott: Certainly!
Costello: Well then who's on first?
Abbott: Yes!
Costello: I mean the fellow's name!
Abbott: Who!
Costello: The guy on first!
Abbott: Who!
Costello: The first baseman!
Abbott: Who!
Costello: The guy playing first!
Abbott: Who is on first!
Costello: Now whaddya askin' me for?
Abbott: I'm telling you Who is on first.
Costello: Well, I'm asking YOU who's on first!
Abbott: That's the man's name.
Costello: That's who's name?
Abbott: Yes.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 08-12-2003, 05:56 AM   #12
Chas's Avatar
Images: 22
He is talking about his house but I guess most of us have figured that out already.
GE never made RV a/c units as far as I can remember. They made plenty of residential split a/c systems though.
Chas
Chas is offline   Reply With Quote
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 08:28 AM
intermittent water leak drcharles2 Plumbing - Systems & Fixtures 2 01-22-2004 10:32 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 05:37 PM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 10:52 AM
