Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-10-2005, 05:42 PM   #1
flyfisherman
Michael
flyfisherman's Avatar
Profile:  1990 32' Excella
Miami , New Mexico
Furnace Vibration and Noise
I recently purchased a 1990 Excella 1000 32' and I have a couple of problems. This trailer was a home for a packrat family and wasps for a number of years before the purchase.
1) The furnace lights and blows warm air, but there is a tremendous vibration and it blew tiny bits of nest material for a few minutes and makes a lot of noise and vibration. Do I need to replace the fan? I'm guessing I'll need to pull the entire unit.
2) The control panel for the holding tanks and propane doesn't work, although the bulbs are okay.
Any help would be greatly appreciated. Oh, I love the forum
Overwintering in the mountains of New Mexico.
flyfisherman is offline   Reply With Quote
Old 10-10-2005, 07:40 PM   #2
driftwood
Remember Burma Shave!
driftwood's Avatar
Profile:  1985 25' Sovereign
1965 22' Safari
Excursion V-10 , S.Florida
Images: 35
Rivet Clean it out ...
Pull the furnace and clean out the 'squirrel cage'. The inlet & outlets will probably need cleaning too. The biggest problem I have encountered is Mud-Daubbers.
May as well 'bang' out the rust, too! A good inspection should be conducted to determine any possible rust-through areas.
You will be able to test the 'smoothness' of the 'squirrel cage' by feeding the motor 12VDC & manually operating the 'sail-switch'. Once you open the unit up you will understand.
After you have re-fit the unit, install a Stainless screen over the outside fittings. You can find them at most complete RV parts houses.
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 10-10-2005, 08:55 PM   #3
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Sounds like a slew of mud dauber nests on the fan blades.
Old 10-16-2005, 08:37 PM   #4
flyfisherman
Michael
Miami , New Mexico
Thanks, I thought it would probably be something like that. I guess I just wanted someone else to tell me the obvious... My next project is the control panel.
1997 "B" generator vibration & noise TuckerT Sprinter and B-van Forum 0 10-06-2004 07:42 PM
"Whirring" Noise in the Driveline at Speed swebster Airstream Motorhome Forums 20 08-15-2003 06:57 AM
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 18 08-18-2002 10:24 AM
Water Hammer melprice Water Heaters, Filters & Pumps 10 07-30-2002 02:10 PM
test
