Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-27-2004, 03:41 PM   #15
walter1
Profile:
From reading this thread and previous links it appears my questions may be answered but not quite sure as most applied to newer AS models.
I am installing a new Suburban NT30SP furnace in my 64 Airstream trailer.
I would like to install a new digital, programmable, set back thermostat.
Am I correct that a conventional Honeywell or Hunter, programmable, internal AA battery powered house thermostat will work on 12vDC system?
walter1 is offline   Reply With Quote
Old 11-27-2004, 06:45 PM   #16
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
The standard 24 volt Hunter thermostats should work fine for you. Here is one that is programmable that is very similar to the non programmable unit that I had put in my Safari. According to the manual for this thermostat, it derives its power from the AA batteries only.
http://www.hunterfan.com/prodSum.php...thermo&sType=4
The major issue is the fact that the internal battery has to supply the power for the thermostat, rather than the transformer found on most furnaces. That's why I used the "Just Right" digital thermostat. If you choose another brand or model (other than these two) you will need to verify the power source for the thermostat. I had the Safari for 2 years with this thermostat and never replaced the batteries. Here is the unit I used.
http://www.hunterfan.com/prodSum.php...thermo&sType=3
Note that many thermostat manufactures offer information or manuals for the indivudual units on their web site.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 06:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 10:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 09:29 PM
test
