Old 03-04-2010, 06:19 AM   #21
Single Slice
2004 28' Safari S/O
Livingston , Louisiana
Great! The bad sail/limit switch trouble has been fixed again. Mine didn't go out all at once, so it was hard to figure out. Great job again - to the forum.
david686 is offline   Reply With Quote
Old 03-04-2010, 07:06 AM   #22
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
U learn something new every day
Originally Posted by Mike Leary View Post
If the furnace has to come out, you should replace the sail (limit) switch
In this case the sail and limit switch are different switches. To get to the sail switch you do have to pull the furnace. On my furnace to get to the limit switch you don't. If I understand the limit switch it kicks in and turns the burner off when furnace temps reach a predetermined temperature.
Old 03-04-2010, 07:07 AM   #23
Mike Leary's Avatar
1984 31' Airstream310
Ajo , Arizona
I wonder why I've never had the sail switch replaced, what does it do?
Mike Leary is offline   Reply With Quote
Old 03-04-2010, 07:20 AM   #24
Lumatic's Avatar
1993 34' Excella
Images: 16
I'm not the Suburban guru, but have learned a few things in the past week. The sail switch (I think also called paddle switch) is in the path of the blower air flow. It needs a certain volume of air passing to mechanically open. It makes sure the blower is pumping enough air flow for the furnace to run properly. If there is not enough air the furnace will not fire.
Old 03-04-2010, 08:20 AM   #25
Single Slice
2004 28' Safari S/O
Lumatic, BINGO. Mine is called a sail switch because it has a 'paddle' set in the air flow to measure pressure to turn the burner on. Mine also has a limit switch that will turn off the furnace if the temp get to high, as in a 'run away' furnace.
Using the heat pump/heat strip instead of furnace. crazylev On The Road... 38 10-28-2016 07:58 PM
heat pump & furnace problem al66pine Furnaces, Heaters, Fireplaces & Air Conditioning 0 10-07-2009 02:04 AM
Furnace on 72 Tradewind pilot lights but no heat RichHog Furnaces, Heaters, Fireplaces & Air Conditioning 10 05-16-2009 02:33 PM
The furnace stopped working ipso_facto Furnaces, Heaters, Fireplaces & Air Conditioning 13 02-24-2006 02:04 PM
Heat Pump and Furnace Operation Cracker Water Heaters, Filters & Pumps 21 12-10-2003 03:10 PM
