Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-17-2003, 01:08 AM   #1
cjholloway
cjholloway's Avatar
Profile:
Furnace Stinks
When we took the trailer out the previous weekend, it got cold enough to need the furnace. When the furnace was running, there was a slight odor. We did not like the "smell" of it and therefore cut the furnace off. This was the first time we had run the furnance in a year and previously had no problems.
The odor had a faint propone smell to it too. Scared me!
Any thoughts as to what the problem might be and what I should do?
I am going to have a propane leak detector and an CO monitor hard wired in the trailer in a few weeks...
Chris
WBCCI #5725
1994 34' Excella 1000
2000 Excursion Diesel 4x4 with Banks Stinger Plus Power Pack and Exhaust Brake
cjholloway is offline   Reply With Quote
Old 11-17-2003, 07:30 AM   #2
87MH
87MH's Avatar
Profile:  1978 31' Sovereign
Katy (West Planet Houston) , Texas
Images: 160
Guess Only
This is only a thought, but it might be just normal operation.
It has been my observation that most home furnaces have a peculiar odor the first light of the season. I had always assumed that it was the rust and dust "burning off" after a almost a year if inactivity.
Good thought on the CO detecter. I would suggest that, after the detectors are operational, to light up the furnace for an hour or so with the door and windows open.
My guess is that the odor will disappear in just a few minutes, and, if problems persist, you will have time to address deficiences prior to your next camping trip.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 11-17-2003, 07:32 AM   #3
nickcrowhurst
Profile:
Chris, are the inlet and exhaust vents fitted with fine screens to keep out mud-daubers, wasps, etc? If not, this could be the problem. If air flow is restricted, incomplete combustion will be the result, and carbon monoxide and/or propane may be present in the exhaust. Your floor is not gas tight, so you may smell the exhaust. You are right to be scared. I would not use the furnace until it has been pulled, dismantled, serviced and re-built. There is probably a fixed price for this at your local dealer ($90 when I had it done), if you do not feel qualified to do it yourself. I watched a technician do the service, so I could learn how to do it myself. You need a set of new gaskets, a wire brush, and a high pressure air line to blow out inaccessible parts. I have walked into a room where a mother and daughter were sitting in front of the TV on Christmas Eve. The furnace exhaust was leaking, and they were both dead. Nick.
Nick Crowhurst, Excella 25 1988, Dodge Ram 2500 Cummins Diesel. England in summer, USA in winter.
"The price of freedom is eternal maintenance."
nickcrowhurst is offline   Reply With Quote
Old 11-17-2003, 08:49 PM   #4
swebster
RivetAddict
swebster's Avatar
Profile:  Louisville , Kentucky
Our 345 had some funky smells coming from the furnaces the first time we lit them up. The front smelled like hot dust (if that makes sense)...but the rear furnace smelled like something burning. Sure enough we had a very old hornet's nest in the exhaust.
I removed the furnace, cleaned everything out and it runs (and smell fine). RV furnaces are pretty simple systems to clean and repair but you need to know what your doing or you can unintentionally create a fire hazard. Your dealing with temp switchs, sail switches, propane connections, ignitors, combustion chambers, blowers and ductwork. Each is a simple system and pretty obvious to the mechanically inclined - but if your not familiar the $90 at the dealer is cheap peace of mind.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
View My ThisOldRV.com Personal Page
ThisOldRV.com
swebster is offline   Reply With Quote
Old 11-18-2003, 09:29 AM   #5
cjholloway
cjholloway's Avatar
Profile:
Thanks for the replies. My 12 yr old son and I will be going out this weekend. We will look to see if there are any obvious issues (bugs, muddaubers, etc), but will take a small electric heater in case it turns cool.
I will have the dealer install the screens and clean the furnace out. I don't think the furnace needs to be replaced, but it is 10 years old...
Chris
WBCCI #5725
Old 11-18-2003, 01:05 PM   #6
zduke4x
zduke4x's Avatar
Profile:
a repair price
I had a furnace fixed with most parts last year and iy was less than 150 bucks as I recall....money well spent...lol..jem
The Silver Buffalo
Saturn with Blue OX towbar
WBCCI # 14067
zduke4x is offline   Reply With Quote
Furnace sets off smoke alarm silverback 2003 International CCD 37 11-12-2006 09:24 PM
Surburban Furnace Ills - HELP Cat Furnaces, Heaters, Fireplaces & Air Conditioning 22 07-07-2005 08:22 AM
R & R a Suburban Furnace Janet's Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 08:19 PM
HELP!! Furnace frustration! Forrest Furnaces, Heaters, Fireplaces & Air Conditioning 18 01-26-2003 08:41 AM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
test
