Old 11-23-2012, 07:44 PM   #1
Floral City , Florida
Furnace starts but won't fire up!
My 2006 Safari (23 ft) heater has worked fine until this past week...when, of course the temperature dropped in Central Florida while we were camping. I turned the heater on, the fan started up, as always, but the heater didn't ignite, and the fan turned off about 30 seconds later. Tried this several times, and each time the same thing happened. I presume the heater has an electronic ignition, and perhaps it isn't working. Owner's manual says fuse on heater circuit also powers the power jack and jack light...which both work fine, so I presume it isn't the fuse. Owner's manual also says not to try to light the furnace using anything but the electronic ignition...so apparently there is no pilot light.
There is plenty of propane...used the oven and stove top so that shouldn't be a problem.
Also, I tried the heat strip in the AC for the first time and it did not heat up very well. I had a 2003 Bambi until June, 2012 when we bought the new 23 footer, and the electric heater on the Bambi was way more effective.
Any suggestions on either the propane heater or the electric heat strip in the AC?
Jimz is offline   Reply With Quote
Old 11-23-2012, 09:23 PM   #2
barbara4rb's Avatar
1992 21' Sovereign
Albuquerque , New Mexico
Mud Dauber's nest?
HI
We had a similar situation with our furnace while over-nighting in Flagstaff, AZ in March 2 years ago. Blower comes on, could hear the click of the igniter, but no ignition, no heat, just blew cold air. Long story short, and about $150 later, our Airstream dealer in Albuquerque found a mud dauber's nest built on the propane nozzle inside the furnace. Little guys like the smell of propane and come in through the external heater vents on the side of the trailer. Good idea to have those vents covered with screen.
Hope that's all it is for you too.
barbara4rb is offline   Reply With Quote
Old 11-23-2012, 10:01 PM   #3
nilesrob's Avatar
Marietta , Georgia
Images: 12
Sounds like the same experience you'd get if you were out of propane, which I know you said is not the case. Do you have a reserve tank that you could switch to?
The Slowsky's
2008 Airstream 27FB International Ocean Breeze
2014 Ford F250 King Ranch 4X4 w/6.7L Diesel, Hensley Hitch
WBCCI #1271
travelwiththeslowskys.com
nilesrob is offline   Reply With Quote
Old 11-23-2012, 10:21 PM   #4
2002 19' Bambi
Lafayette , California
In years past, we have had the same effect, but with more than one cause. Once, the ignition board died. We replaced the board and the furnace worked for some time. The second time the gas regulator went bad and was keeping the gas pressure too low. We replaced the regulator and everything was again fine ... for a year or so. Then the sail switch stuck and needed to be replaced. The new one stuck again, but, by that time, I knew where to bang on the side of the furnace to get the switch to work again. We now carry a spare ignition board and sail switch with us. Since resorting to that, the furnace has worked perfectly for years.
In all case, the symptoms were exactly as you have described: furnace goes on, tries to ignite (without success), and (after three tries at ignition) shuts off.
Tim
Tim A. is offline   Reply With Quote
Old 11-24-2012, 06:52 AM   #5
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
With the heater on my 2005 Bambi, the fan comes on, and a few seconds later, there is a clicking sound of the electronic ignition trying to ignite the flame. In my experience, if you don't hear this sound, it would indicate an ignition problem. My heater failed last year, and it turned out to be the burner. Part of it had nearly disintegrated. Fortunately, it was covered by the extended warranty, and the repair facility also replaced the ignitor, but that part looked fine to me. It's possible that it could be the ignition board, but it could be something as simple as some corroded contacts.
I realize it is a different system, but my water heater wouldn't ignite a while back, and there was no clicking sound. I pulled and checked the board, and the contacts looked very clean, but I cleaned them off anyway, and put it back in. It's been working fine ever since.
Hoping it's something simple.
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 11-24-2012, 07:14 AM   #6
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by barbara4rb View Post
HI
Times two...broke it up with sharp poker and vac'd it out with a piece of pvc on the shop vac.
A square of furnace filter to keep them out during storage.
(also fridge & h2o heater)
Old 11-24-2012, 09:18 AM   #7
Moflash's Avatar
2007 28' International CCD
Springfield , Missouri
Is you propane water heater working???
Furnace Problem NOAZRK2690 Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-10-2014 08:34 AM
My furnace blows... out its own flame godaddy64 Furnaces, Heaters, Fireplaces & Air Conditioning 15 12-13-2011 08:15 PM
Furnace Problem Stone Ridge Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-05-2011 06:30 PM
Duo-therm and furnace question... NoMoSOBs Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-21-2011 09:17 AM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
