Old 01-24-2011, 09:18 AM   #15
Wise Elder
Jammer's Avatar
2010 30' Classic
DC blower motors usually do fail due to bearing failure caused by seal failure and loss of lubrication.
When a replacement motor is unavailable or excessively costly it is possible to disassemble the motor and lubricate the bearings. I have done this several times on cars, trucks, and ag equipment, though never on a furnace. My experience has been that it doesn't always help (sometimes the bearings are too far gone for lubrication to help), and at best it's a fix that will last a few years. After all, it's the seal failure that led to the problem in the first place, and squirting some oil in there doesn't do anything to fix that.
I had a planter (for corn) that had individual electric blowers for each row to provide air for the metering system. I ended up drilling holes on the outside of the motors so I could drizzle in some oil every year. It worked out OK but then the motors were easily accessible.
I'm guessing Skater's rv tech may have re-oiled the bearings for similar reasons. It can be nearly impossible to remove a badly rusted blower wheel without damaging it and without a replacement wheel in hand it would be tempting to take shortcuts.
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 07:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
