Old 01-10-2010, 12:04 PM   #1
Florence , South Carolina
Furnace Service
I have a Suburban NT-34 in my trailer. Over time it has been balky firing up and I've had to reset it most times before it would fire up. During the hollidays it refused to fire. I contacted my local service man who came out and managed to coax it into firing up but could tell that only about 1/3 of the burner tube was burning. After removing the furnace and dis assembling found debris in the burner chamber from mud dobbers and found the orifice partailly clogged. Since the furnace was out I splurged and installed a Dinosaur Electronics Home. High quality circuit boards for RV appliances. Dinosaur control board. ( I'll have the origianal board as a replacement for my DSI water heater ) What a difference. It fires right up and now there is hot air coming out of the vents instead of luke warm air.
I had previously added the Hunter T'stat which is much improved over the original thermostat.
'90 Suburban R2500
'90 Avion 34V
Cummins-Onan P4300ie
Reese Dual Cam HP
Prodigy
RollingCondo is offline   Reply With Quote
Old 01-10-2010, 01:36 PM   #2
'90 Suburban R2500
'90 Avion 34V
Reese Dual Cam HP
Prodigy
As they say in Brroklyn, "now your cookin".
Most fixes are easy, once the problem has been diagnosed.
Suburban has a screen kit available that is installed on the outside of the trailer. That, stops the mud dobbers.
Hopefully, when the furnace was on the bench, you replaced all of it's gaskets, especially the once that goes around the heat exhaust pipe as it goes thru the walls of the trailer.
You know, that carbon monoxide stuff.
Problems with XM Service Bluto Computers, Internet & Satellite 12 04-11-2009 04:21 PM
Service RedSHED Off Topic Forum 0 11-09-2007 06:08 PM
Griffith RV Service Dwight Commercial Listings 5 04-21-2005 06:31 PM
Service Scott Hopkin Commercial Listings 6 04-07-2005 07:08 AM
service... canny_banjo_man Airstream Motorhome Forums 6 11-12-2002 05:52 PM
