Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 06-09-2006, 02:25 PM   #1
kdenault
Profile:  1965 26' Overlander
Holland , PA
Furnace replacement with fireplace?
In my "new to me" 65 Overlander 26 footer, I am needing to install an A/C and replace the rusted International furnace. With these two larger ticket items looming over me, I've resigned myself to just spending the cash and doing it right the first time.
What does that mean--well, let's add the fireplace! I've seen pics of Pearl54FC's installation of the Newport Propane fireplace--fabulous.
I was thinking about purchasing a Carrier Heat Pump (15,000 BTU's-I think-of heating and cooling) for the A/C installation and then installing the proprane fireplace as an additional heat source instead of a new furnace. I don't plan on doing much cold weather camping--so, i though that this might be a sufficient way to kill 3 birds with 2 stones ---the heat pump for cooling and some heating, and the fireplace for additional heating.
The only glitch that I can foresee is the lack of a heat source to "warm" the holding tanks to prevent possible freezing if the temps dip down at night. And, I'm not sure if the combines heat output of the fireplace anf the heat pump would be sufficient to heat the trailer. Also, does the fireplace have a fan to help circulate the heat?
Does any one have any thoughts about the feasibility of this plan?
Kathy
kdenault is offline   Reply With Quote
Old 06-09-2006, 05:03 PM   #2
65GT
Supposititious Blue
65GT's Avatar
Profile:  1953 21' Flying Cloud
1965 20' Globetrotter
WBCCI Metropolitan New York Unit #072 , New York
Images: 26
I don't know if it will have all of your answers but if you search for Newport you're likely to come up with a few different threads. Here's the most recent:
http://www.airforums.com/forum...hlight=newport
__
7000+ Airsteam families having fun!
1100+ Airstream Events including 650+ Rallies in 2008!
SaveWally's WBCCI Unit Guide
65GT is offline   Reply With Quote
Old 06-09-2006, 07:56 PM   #3
Dale M
Profile:
Newport FYI
I have the Newport fireplace in my Islander 36 sailboat on Lake Superior. I installed it 3 years ago and have had time to field test it on those cool mornings on the hook. My impression is that it will not be powerful enough to heat the inside of anything but a small Airstream. It is a well made good looking unit that adds a lot of bling to an interior and the flicker of the flames is great for the late night activities. Dale M
Dale M is offline   Reply With Quote
Old 06-09-2006, 10:17 PM   #4
kdenault
Holland , PA
It won't be alone
Dale,
I'm planning on paring the fireplace with a 15,000 BTU heat pump as another heat source. I think the old furnace put out btwn 24,000 and 30,000 BTU's (very warm at 30,000), so-- I thought--if it's a 3 season trailer, the fireplace and the heat pump may be OK
KAthy
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 06:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 10:41 PM
Two ?'s Furnace and weather stripping escapeez Leaks - Weatherstrips, Gaskets, Caulks & Sealants 2 09-15-2002 07:10 PM
test
