Old 11-22-2011, 11:00 AM   #15
1972 31' Sovereign
1979 29' Ambassador
west monroe , Louisiana
I am considering a 'Northstar' catalytic heater to replace the existing one that's giving me problem. The furnace replacement will still be on my list to do, but the catalytic heater install will be a quick, easy fix for the on coming winter months. Thanks.
litlgeezer is offline   Reply With Quote
Old 07-24-2012, 06:36 PM   #16
1972 31' Sovereign
1979 29' Ambassador
Originally Posted by idroba View Post
Probably not. Although the box size may be the same, the new ones have a different electrical connection system, different cooling vent holes for the electronic ignition, and usually a different gas inlet location from the one you have in a '72. The outside inlet and exhaust tubes probably are in the correct location.
I would recommend you consider changing both the guts and the box both. It is not difficult to remove the box, it is generally held in with only two screws in the bottom, near the front. It will slip right out, assuming that you are not one of the unlucky ones with a furnace with a shelf on top of it, and a bar in front of it.
Let us know how you make out.
Apologize for dropping off the radar about the furnace. Haven't tackled it yet - summertime. I did install a new Olympian catalytic heater and it worked well for the 'cool' winter nights here in the south. I do want to revisit the furnace eventually, just too many other higher priorities right now. One thing I have learned is to take the challenges at a moderate pace, one at a time. Otherwise, it turns into work.
Furnace Replacement Bethany533 Classic Motorhomes 17 03-08-2013 05:42 PM
Duo-therm and furnace question... NoMoSOBs Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-21-2011 09:17 AM
Suburban furnace trying to kill me? icebox500 Furnaces, Heaters, Fireplaces & Air Conditioning 4 07-31-2011 10:21 PM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
Suburban furnace replacement for '66 Trade Wind Ben in MT Furnaces, Heaters, Fireplaces & Air Conditioning 0 05-17-2011 08:12 PM
