Old 02-01-2013, 10:30 AM   #1
SomthngShiny's Avatar
1976 31' Excella 500
Walker , Michigan
Furnace Replacement
Does anyone have experience with inverting a Suburban SF style furnace to align the exhaust ports to an older (76) AS?
Long Time Wannabe, First Time Owner
SomthngShiny is offline   Reply With Quote
Old 02-01-2013, 10:43 AM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Do you want to use an SF furnace because you already have it on hand? There are lots of threads about replacing 70s furnaces with the current NT-series Suburbans. Since the SF unit is a similar height to the vent itself, I don't understand why you need to invert it to use the existing vent, but you'd probably have to build a platform (as is required for a newer NT.)
David
Old 02-01-2013, 11:45 AM   #3
Walker , Michigan
I believe that the SF vents on the opposite side as the NT. Ive read that the SF's are quieter with Less Amp draw and are much less expensive.
Old 02-01-2013, 12:00 PM   #4
DKB_SATX's Avatar
1976 Argosy 28
I don't know about the sound level in operation, but according to Airexcel (Suburban) the amp draw is less on an NT.
NT-30SP draws 4.5 amps
SF-30 draws 7 amps
power consumption is closer in the high-BTU furnaces, but still slightly lower for the NT:
NT-40 draws 8.5 amps
SF-42 draws 9.0 amps
It looks like the SF units are slightly cheaper, but not a big difference. $10-$15 difference in the sites I checked.
David
Old 02-02-2013, 07:48 AM   #5
Walker , Michigan
Thanks soo much for the info.
