Old 03-04-2007, 09:04 PM   #1
1970 31' Sovereign
Ponder , Texas
Send a message via Yahoo to rocat1997
Furnace removal help!
Hi everyone,
I need to remove the furnace in my 1969 Sovereign International 31 foot. The furnace is located below the stove in the cabinet. It needs a major cleaning and inspection. I cannot tell what brand it is. Most all of the tags are unreadable. I was wanting to just take it out and take it into the dealer to be reconditioned. Any help would be helpful to me. The trailer cannot be taken in. It is permanently in a trailer park and besides that I do not have a truck to pull it with at this time. I am very handy with tools. I just want to know what to do so when I tackle the job it will go well. The furnace worked well for 2 years, then, it started having problems with the pilot light going out on its own. Also, at times, there is a grey steam coming from the vents outside. I am just worried about it and want to get it checked. Thanks for the help,
Roger
rocat1997 is offline   Reply With Quote
Old 03-04-2007, 09:31 PM   #2
69 Caravel
KHarris's Avatar
1969 18' Caravel
Bayfield , Colorado
Hi Roger,
I'm not sure if your furnace is the same as ours on our 69 Caravel, but we recently removed it. It was the original furnace, and the pipe was pretty rusted. It vented to the outside.
It didn't want to budge, but we sprayed it multiple times with wd40, liquid wrench, etc, then let it sit for several days. After tapping to loosen the joints, we had to insert a pipe diagonally through the outside vent for leverage then put some muscle behind it to loosen it. Once that was free, we removed all the old pipe, and the furnace came out the front.
We had intended to have a new one installed, but we took it to a local RV shop and they convinced us it would be worth cleaning and rebuilding the original one, which is what we did. So far so good.
Hope that helps.
Krista
I Dream of Airstream!
KHarris is offline   Reply With Quote
Old 03-04-2007, 09:38 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Don't forget to remove the bvolt from the outside vent!
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 03-05-2007, 07:36 PM   #4
1970 31' Sovereign
Ponder , Texas
Hi everyone,
After taking the bolt off from the outside and unhooking the gas line, what else do I need to do? Does the electrical need to come out? Just trying to get an idea of the whole process. Thanks for the help,
Roger
Old 03-05-2007, 08:27 PM   #5
bibbs's Avatar
1977 Argosy Minuet 6.0 Metre
1973 21' Globetrotter
1975 26' Argosy 26
Vista , California
Roger
on my furnace the inside is removable there is one screw from the outside in the center of the exhaust vent and two screws going down inside between the fins,unplug the wireing conector and remove the gas pipe.A little wiggle and it slid right out.
hope this works for you
Doug
bibbs is offline   Reply With Quote
Old 03-12-2007, 07:49 AM   #6
1970 31' Sovereign
Ponder , Texas
yes, that does help. I will give it a try next weekend and see what we get.
One more question. Is any of the parts of the furnace still available? The lighter? Other items that might be required? Thanks for the help.
Roger
Old 03-16-2007, 07:39 PM   #7
Dugger
1963 30' Sovereign
Midlothian , Texas
Rodger, I'm about to remove my heater from a 64 Sovereign and found your post. Am I understanding you removed thre heater from the outside of the trailer ? I see your in ponder Tx, I use to live in Jacksboro and now in Midlothian. This is my first AS and Doug
Dugger10 is offline   Reply With Quote
Old 03-26-2007, 08:10 PM   #8
1970 31' Sovereign
Ponder , Texas
I haven't even attempted it yet. But, it would come out from the inside.
Roger
Old 03-26-2007, 08:52 PM   #9
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
We found parts for our Suburban through a local RV store. If you have one close by, ask them if they can order parts for you.
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 07:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
