Old 02-10-2007, 01:37 PM   #1
Exeter , Rhode Island
Furnace removal - 89 Excella
I'm having furnace problems and would like to remove the furnace on my 89 Excella 32' trailer. On the exterior of the trailer there are 3 vent holes. Two of the vents are together and one slightly to the side towards the rear. Do these vent plates have to be removed to get the furnace out? Also I would appreciate any info on what has to be taken loose inside for removal. The problem I am having is that the burning won't ignite. The fan comes on but just blows cold air. I have replaced the limit switch. I can here the igniter click after the fan comes on. All of the other gas appliances work fine. I'm thinking maybe the sail switch is bad or maybe the circuit board.
Ben
Rob30044 is offline   Reply With Quote
Old 02-10-2007, 02:27 PM   #2
Condoluminum's Avatar
1988 25' Excella
Sunnyvale , California
Images: 13
Send a message via AIM to Condoluminum
Try the search...
Ben-
The exterior vent grills don't need to be removed. Search using tab above for "furnace" and "removal" and "repair" to see threads with pictures for how others have done it... Not very complicated, though important to secure gas line and reconnect without leaks...
You should have (or get..) furnace service manual applicable to yours before you begin..
Condoluminum
Condoluminum is offline   Reply With Quote
Old 02-10-2007, 02:35 PM   #3
Excella CM's Avatar
1978 31' Excella 500
Venice , California
Often times the solenoid gas valve gets sticky and wont open properly. It can be dis-assembled and cleaned or replaced. It's a common problem.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 03-02-2007, 08:50 PM   #4
Originally Posted by Condoluminum
Ben-
I found a service manual for my furnace after searching through several pages of threads. I did remove the exterior vent grills as it made removing and installing the furnace easier. The ignitor board was bad. I replaced it today. I HAVE HEAT!!!
Ben
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 07:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
