Old 06-06-2009, 09:47 AM   #1
1977 Argosy Minuet 6.0 Metre
SPOTSYLVANIA , Virginia
furnace question
I HAVE A 1977 sUBURBAN nt-16S-My outside vent plate mounts with 6 screws and none are 3 " long-am I missing that long screw and if I am what size is it? bThe manual infers all models have this screw
vcu70 is offline   Reply With Quote
Old 06-06-2009, 11:08 AM   #2
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
you got my curiosity up. I checked the vent plate on my 1970 Caravel and 1972 Overlander, both mount with 4 screws and none of them are long.
I do recall my 1977 Safari having six screws in the vent plate (long since removed). It seems there was some connection to the inner skin, which is usually 1-5/8" to 1-3/4" (which would require a 2" to 2-1/4" screw). If a long screw(s) is required, I would assume it's to ensure that the intake and vent for the heater remain securely in the holes in the inside skin, so that they are exposed only to outside air.
Zep
Old 06-06-2009, 12:04 PM   #3
zep, I went back out and took mine apart again. Under the outside cover is a round plate that is connected to the furnace with two screws and 4 on the outside plate makes 6-the manual shows that 3 inch screw in the middle so mine cannot have one and yours neither I suspect
Old 06-06-2009, 01:25 PM   #4
1975 31' Sovereign
1977 23' Safari
then I think you are good to go!
73 overlander furnace question Lothlorian Furnaces, Heaters, Fireplaces & Air Conditioning 8 02-13-2009 09:53 AM
Newbie question about suburban furnace rec Furnaces, Heaters, Fireplaces & Air Conditioning 5 10-25-2007 07:05 PM
New Suburaban furnace intake question sequoiacoast Furnaces, Heaters, Fireplaces & Air Conditioning 9 07-07-2006 09:41 AM
Furnace Question... bhsl8 Furnaces, Heaters, Fireplaces & Air Conditioning 25 03-18-2006 07:44 PM
Old Suburban Furnace Question Jeffrey Stoecker Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-07-2006 03:11 PM
