Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 11-28-2005, 06:23 PM   #1
65GT
Supposititious Blue
65GT's Avatar
Profile:  1953 21' Flying Cloud
1965 20' Globetrotter
WBCCI Metropolitan New York Unit #072 , New York
Images: 26
What comes after POP?
A 61 trailer had a furnace made by International Oil Burner Company. It's main problem is that it explodes because the burner falls apart in time, because of rust. DO NOT USE IT, OR ATTEMPT TO USE IT!!!!!!!!!!!!!!!!!!!! Andy
Andy,
Did they use this furnace in '65? I had a small scare after lighting what's in mine. Counter to floor model -- about 18-24 inches wide. A full height grate with small squares in the grill. The pilot is bottom left about 6" off the floor.
I lit it, the pilot worked for a while, it ramped up, gave up a little bit of fumes or moisture/dirt burning off (not sure which), and then a loud POP and it went out. It was actually probably a little louder than a pop, but not quite a BANG!
Thanks!!
__
7000+ Airsteam families having fun!
1100+ Airstream Events including 650+ Rallies in 2008!
SaveWally's WBCCI Unit Guide
65GT is offline   Reply With Quote
Old 11-29-2005, 10:40 AM   #2
Commercial Vendor
Profile:  Corona , California
65GT
The International Furnace was mounted underneath the galley cabinet.
From your description, it sounds like you have a small wall heater or a catalytic heater.
In either case, if it doesn't work "perfectly" get rid of it.
The gamble is too great.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Old 11-29-2005, 06:23 PM   #3
65GT
Supposititious Blue
65GT's Avatar
Images: 26
65GT -- In either case, if it doesn't work "perfectly" get rid of it. The gamble is too great. Andy
Andy,
Thanks for the response. I'll take a pic of it tomorrow. Getting rid of it is the hard part. Aren't I suppossed to do my best and KEEP the original furnace, or at least attempt to get it repaired/refurbished?
I do like that Dickinson Fireplace, but I can see where that belongs in the '53 FC . But the GT, well, there's no decent spot for a true vertical fireplace and if I can't go WOW then I'd rather have the original.
I'll post the photo tomorrow when it's light out. Thanks!
__
Old 11-30-2005, 10:37 AM   #4
Commercial Vendor
65GT
You have done your best.
You have determined that the wall furnace is bad.
Parts, to my knowledge, are no longer available.
Safety is the key issue.
Explosions are never nice, especially in a confined area. LPG leaks can be and are deadly.
Finish the homework, bite the bullet, and replace it.
Inlandrv.com
800-8777311
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 08:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 06:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 10:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 10:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 09:29 PM
test
