I know that the circuit board in my Suburban NT-30SP is bad because it will not open the gas line solenoid, even though the sail switch, limit switch, and the time delay relay all combine to send 12v to the circuit board. In addition,
THERE IS NO (BURNER FLAME) SENSOR PROBE INSTALLED IN THIS FURNACE!!????? and no provision for one?? Am I missing something here?
Dick
That is correct. Only 1 wire, that wire is the igniter.
There is no provision in the plate that supports the igniter and burner for a wire going into monitor the flame!!
Inside the above mentioned plate there is NO provision for a sensor. Only the spark rod and the ground rod. I am confused.
Dick
I thought mine had 2 wires, but I may be wrong. I just had to replace the board in mine or the same reason. While I had it out I did the sail switch too.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Brett,
Positive: NT-30SP
I downloaded a Suburban Dynatrail Furnace Manual.
Get this!
There is a discrepancy between the wiring diagram glued onto the furnace, and the wiring diagram in the Service Manual for the NT30-SP!!
My unit wiring diagram does NOT show a sensor!!
I think that I need to call the factory.
Dick
