Old 12-10-2005, 03:20 PM   #1
1973 24' Argosy 24
Pensacola , Florida
Furnace problem
Hello to all! I recently became the proud owner of a 1973 Argosy 24 and while evaluating the trailer and systems, I've discovered a problem with the furnace. I can light the furnace, the pilot light will stay lit, but when I turn up the theromstat, the movement of air in the furnace blows out the pilot light. I read the instructions on the furnace (I have no manual) and it refers to incorrect operation if the pilot light cover and "air shutter adjustment cover" is not tightly secured. I have no idea what the latter is.
Any ideas will be greatly appreciated!
ddsouth is offline   Reply With Quote
Old 12-10-2005, 03:34 PM   #2
2006 30' Classic
Farmington , New Mexico
Images: 14
I would be suspicious of a cracked fire box. I don't think there should be any air coming into the area of the pilot that would blow it out.---- Pieman
Mike Lewis is offline   Reply With Quote
Old 12-10-2005, 03:48 PM   #3
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Depends on the make of the furnace. Suburbans have two fans. One blows thru the combustion chamber the other end of the blower motor powers the fan that distrubutes the air throughout the Airstream. Only way I know to be really sure the firebox does not have a hole is to dismantle furnace and look. The coleman furnace does not have a fan for the combustion chamber and depends on natural convection. It has a large square box sticking thru the sidewall of the trailer.
Old 12-10-2005, 04:39 PM   #4
CanoeStream's Avatar
St. Cloud , Minnesota
Welcome to the Forums ddsouth! Do a Search on keywords: furnace recall. DwightDI's suggestion is a good start -- there's something about a tube on the back that didn't hold up like they expected. There's a carbon monoxide risk unless checked out expertly. No, I'm not the expert but am glad you checked in here!
5 meter Langford Nahanni
Old 12-10-2005, 05:25 PM   #5
1973 24' Argosy 24
Pensacola , Florida
Thanks for your replies!
I failed to mention that the unit is a Suburban(I don't know which model).
Old 12-10-2005, 05:43 PM   #6
StingrayL82's Avatar
San Angelo , Texas
Images: 37
According to Ron, at South Jersey RV, there was a recall on the Suburban furnace, but I think it was in 1972, not 73. Still it's something to check into. I think it had something to do with the crossover tube? I went ahead and bought a new NT-30 to save from having an Airstream barbecue.
Frederic
Frederic
1971 Sovereign International - SOLD
2004 F-350 King Ranch
AIR # 8239
EX-WBCCI # 8371
StingrayL82 is offline   Reply With Quote
Old 12-10-2005, 08:21 PM   #7
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Just junk it...
Honestly, from my 76, the crossover tube was shot (and you can't tell until you fully pull the furnace apart). I was suprised my trailer didn't burn - or I didn't die of CO poisening. There is a "burn plate" under the manifold - my manifold had a couple of holes on the bottom.... which were burning through my burn plate. Again - couldn't tell until it was fully apart. My furnace was working great, until simular symptoms that you relate.
I think I'm worth $500.00 for a new one.
My 2cents.
Marc
Old 12-10-2005, 11:08 PM   #8
1977 31' Sovereign
1989 34' Excella
Later model furnaces the other posters referred to do not have a pilot light. They have an electronic ignition. If you search for Suburban Recalls in the files you will find out which models have the rubber cross over pipe. I think it was later than yours. After than problem, they went back to metal cross over pipes so the new ones you buy are not a problem. The burnt or cracked cross over could allow some carbon monoxide to enter the trailer. If you do not really know what you are doing it is best left to pros. After all you have only one life and Campers World will likely only charge you $200 labor charge to put in a new $580 furnace.
Old 12-10-2005, 11:21 PM   #9
1977 27' Overlander
Huntsville , Alabama
Send a message via Yahoo to dustyrhodes
I just pulled the furnace out of my new 77 Overlander. I didn't trust a 30 year old furnace in my home and I don't trust it in my Airstream either.
dustyrhodes is offline   Reply With Quote
Old 12-11-2005, 12:30 AM   #10
1975 Argosy 26
1963 24' Tradewind
It's not hard to replace...
do a search for NT30 on the forums. It will give you some insight (or on furnace replacement).
Marc
Old 12-11-2005, 01:12 AM   #11
72 tradewind's Avatar
1972 25' Tradewind
Willis , Texas
Images: 8
pilot problem
My furnace did the same thing until I adjusted the pilot to a slightly larger flame.
72 tradewind is offline   Reply With Quote
Old 01-12-2006, 05:19 PM   #12
BrianWSNC's Avatar
thank you Tradewind. I have the same problem, but I tried adjusting the pilot light and the screw doesn't do anything. it was too cold and i was too tired to remove the pilot light tube so I just gave up and switched on the electric heaters.
someone told me the pilot light tube is probably rusted up inside, causeing the flame to be too small and not heating the thermocoupler enough. I will replace it when I return there in a few weeks.
BrianWSNC is offline   Reply With Quote
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Stove jeanarlene Stoves, Ovens & Microwaves 25 08-27-2004 08:39 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
