Old 03-21-2015, 07:24 AM   #1
1999 31' Land Yacht
Dillon , Colorado
Furnace Problem
My 99 Land Yacht 31 furnace does not light but the blower works. There was a water leak from the kitchen faucet dipping into the furnace compartment that may have caused a short i the circuit board. Any advise?
LawrenceL is offline   Reply With Quote
Old 03-21-2015, 07:35 AM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Furnace Problem
It may be that the board connectors are corroded from the moisture. Unplug them and clean the contact points. Also the pilot area igniter and burner may need cleaning up in order for you to get spark.
If you need a new board. The dinosaur boards are a better buy and more reliable than the OEM boards.
Are you sure you have gas to the furnace?
Old 03-21-2015, 07:42 AM   #3
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Could you post what furnace you have.
mayco is offline   Reply With Quote
Old 03-23-2015, 10:17 AM   #4
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
The igniter may also have worn, and the gap is too wide. I had to finally change the igniter in my furnace, and now it works well.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 03-24-2015, 06:55 PM   #5
1988 29' Excella
Plant City , Florida
I have one doing the same thing blower comes on but there is noise like it's even trying to fire I would be interested know if you find out the problem
Joe
wjcwill is offline   Reply With Quote
Old 03-25-2015, 08:20 AM   #6
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Joe
Joel, your furnace is most likely the same as mine, and is located under the stove. If you remove the cover panel, you will see the igniter - it's just like a spark plug with a gap. I removed it and cleaned the tip with a wire brush, and then using pliers, adjusted the gap to about 1/8th inch. After several adjustments, I noticed that the stiff wires making up the sparking gap were burnt and shorter - so I bought 2 new igniters (just make sure that you get exactly the same part number igniter), one to replace the worn one and the other to put into a small zip-lock bag fastened with duct tape attached to the inside of the compartment door in case I need to replace the igniter again.
BTW, I have spares for "critical" items kept near where you need them - I have a spare water pump in a plastic bag beside the one in service and a spare seal for the toilet bowl in a bag, with instructions, under the vanity.
VE3JDZ
AIR 12148
Old 03-25-2015, 05:11 PM   #7
1988 29' Excella
Yes it it is located under the stove I will check the igniter is the a part number on it or do I use the model and serial # of the furnace it is a suburban furnace
Old 03-28-2015, 10:19 PM   #8
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I took the old one with me to the RV parts store and they were able to match it. It also helps to tell them the model number of the furnace - if you have the AS Owners' manual, you can show them the drawing of the igniter.
VE3JDZ
AIR 12148
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 09:17 AM
furnace problem nwclassic Furnaces, Heaters, Fireplaces & Air Conditioning 10 01-11-2007 11:15 PM
furnace problem..... norbert Furnaces, Heaters, Fireplaces & Air Conditioning 12 11-17-2003 08:50 AM
New Airstream - Air conditioner/Furnace problem mariffe Electrical - Systems, Generators, Batteries & Solar 12 04-16-2003 04:26 PM
Furnace problem Paul Daugherty Airstream Motorhome Forums 20 02-19-2003 03:31 PM
