Old 06-27-2008, 06:29 PM   #1
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
furnace on/off cycling
When we were out doing our shakedown trips we used the furnace a few times. It ran great when the trailer was much colder than the setting, but cycled pretty consistantly when it approached temp (fan on, light of flame, burn, fan only, off, maybe a minute and repeat). The unit was installed when we purchased the trailer and was the only new thing in the beast. It is an Atwood 7916 electronic ignition.
The thermostat however is original. I'm planning on replacing it with a new one tomorrow but finding accurate testing of it difficult with daytime temps reaching 104+ the next few days. Has anyone encountered this type of problem and do you think I'm on the right track? Our next trip is only a few days away and is more than just a couple nights so want to make sure we have it resolved before we go. Thanks!
Here's a link to a seller of the furnace (I don't know where they PO got it)
Hydro Flame Furnace - Hydroflame Furnace Parts
goransons is offline   Reply With Quote
Old 06-27-2008, 06:56 PM   #2
Central , Mississippi
Ours did that when we were camping in the 20's and 30 degree range during our yellowstone trip. I suspected the deadband range of the thermostat was too narrow but like ya'll, it's in the 90"s so I have somehow forgotton about it...
In reality, some thermostats have adjustable deadbands that when set for, say 70 degrees, don't turn off the heat till an adjustable temp ABOVE that point, say 72 degrees. By widening that range the heater will stay off longer between cycles. The down side is... pull up the covers, heater comes on, kick off the covers, heater goes off...repeat all night long...
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Furnace Thermostat cycling Lumatic Furnaces, Heaters, Fireplaces & Air Conditioning 2 05-03-2008 08:47 AM
Water pump cycling every 1-2 sec?? BOBHASTINGS Water Heaters, Filters & Pumps 19 09-06-2006 04:22 PM
Water heater rapid cycling on/off BillTex Water Heaters, Filters & Pumps 8 07-13-2006 11:50 AM
furnace fast cycling - thermostat adjustment emanon25 Furnaces, Heaters, Fireplaces & Air Conditioning 2 09-28-2004 09:06 PM
Water Heater Cycling? BigAl Water Heaters, Filters & Pumps 0 07-06-2004 08:48 PM
