Old 01-29-2014, 08:00 AM   #1
1989 25' Excella
Furnace odor
When operating furnace in 89 Excella, the heat comes with a stale dusty odor. My guess is something in heating system needs cleaning.
Any advice on what and how to access it?
PAL07 is offline   Reply With Quote
Old 01-29-2014, 08:17 AM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Most furnaces, home or RV, will have a scorched odor when started up for the first time each winter, as the dust that has accumulated on the heating element is burned off. The smell should disappear on its own. If it doesn't disappear, then a small vacuum cleaner applied to the heating element from inside the trailer should do the trick. But vacuum the heating element after the heater has cooled down. No sense risking a burn.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 01-29-2014, 09:21 AM   #3
1989 25' Excella
The odor does continue with usage. Will try the vacuum approach. Is the element accessible without removing the Magic Chef oven above it?
Old 01-29-2014, 09:58 AM   #4
1974 Argosy 20
Kooskia , Idaho
I hate to suggest it, but there is a possibility that a mouse or other critter died in your ductwork. I have never hand lingering odor in my furnace in any of the RV's I have owned, and that is way too many.
Old 01-29-2014, 10:16 AM   #5
1977 Argosy 24
Milltown , Wisconsin
It should have a removable door facing the hallway. If it's a Suburban furnace there are 2 screws, one on each side of the door, centered up & down.
ventport is offline   Reply With Quote
Old 01-29-2014, 06:25 PM   #6
1989 25' Excella
Interesting point. I just noticed a repair to the duct under sink area, and was wondering why it had been repaired. I think I know now.
Will begin inspecting ducts, starting with that one.
Furnace Problem NOAZRK2690 Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-10-2014 08:34 AM
My furnace blows... out its own flame godaddy64 Furnaces, Heaters, Fireplaces & Air Conditioning 15 12-13-2011 08:15 PM
Furnace Problem Stone Ridge Furnaces, Heaters, Fireplaces & Air Conditioning 3 12-05-2011 06:30 PM
Duo-therm and furnace question... NoMoSOBs Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-21-2011 09:17 AM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
