Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-17-2004, 07:22 AM   #1
balrgn
balrgn's Avatar
Profile:  1974 27' Overlander
Rockingham County , New Hampshire
Images: 74
Question Furnace odd smell
We had a gas odor in our '75 Trade Wind? Checked everything, Flame, connections then the light bulb came on. Low fuel. Checked the tank, it was about 1/4 full. Swapped over and now all seems well!
CO2 detector installed.
I let the furnace heat up the camper with the center vent open 1/4. Checked for leaks, there is no smell when the furnace is not operating. Pilot is adgusted properly. With the blower on and the front panel off CO2 detector alarms (after 10 minutes) I need to find a resource for technical data for a Suburban NT22A???
Found the manual online, removed the unit, found a cracked fitting? more to follow..........
Last edited by balrgn; 10-17-2004 at 12:32 PM. Reason: Smell has not gone away :O(
balrgn is offline   Reply With Quote
Old 10-17-2004, 07:53 AM   #2
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
a good tip for those who might be new to all this Rv stuff. Good idea to have a CO sensor installed for cold weather sleeping especially. Leaks can be hard to smell, but still have their effect on you.
Rallys twice a year..Lots of fun, food, and aluminum.
http://groups.yahoo.com/group/gaairstreamcampers/
http://airstreampassion.blogspot.com/
My Music Site:
HTTP://ALANDAVIDSONGS.COM
Old 10-17-2004, 09:13 AM   #3
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
While it never hurts to practice good safety and check for leaks, be aware that in some situations I have also smelled what seemed to be gas when in low tank situations. Apparently the chemical added to propane to give its distinctive odor can accumulate at the bottom of the tank and be much more present in the exhaust of your different gas appliances when they are in operation.
My advice is to check the gas hose and fittings that service your tank. If they show no evidence of leak, then you are probably experiencing the same situation. Especially when the full tank seems to be fine.
Regards,
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
Old 10-17-2004, 06:39 PM   #4
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
I am not 100% sure which model, but some of those Suburban furnaces had a problem with cracked inlet and exhaust tubes. They would leak exhaust into the trailer, causing CO poisoning problems. I have one of those furnaces, and solved the problem by installing an A/C unit with heat.
Old 10-17-2004, 09:15 PM   #5
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Furnace recall
Here is what Terry is referring to. There are other threads -- do a search on the words: furnace recall.
Old 10-18-2004, 05:07 PM   #6
balrgn
balrgn's Avatar
Images: 74
Suburban Gas odor
Thanks, I pulled the unit and found all the female comperssion fittings cracked, replaced all the fittings, Ran the furnace for an hour, NO CO2 problems and no more odor!
Now I need to go after the gas portion on the refigerator.... (electric work perfect)
Regards,
Jack
Funny smell when running furnace yukionna Furnaces, Heaters, Fireplaces & Air Conditioning 10 10-07-2004 03:03 PM
R & R a Suburban Furnace Janet's Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 08:19 PM
CO problem with furnace :eek: yukionna Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-25-2004 07:35 PM
LP Gas smell when furnace first kicked on Impala SS Guy Furnaces, Heaters, Fireplaces & Air Conditioning 3 09-30-2003 01:08 PM
Furnace exhaust smell Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-25-2003 08:54 PM
test
