02-06-2012, 08:54 PM
2005 30' Classic
Kingston
Furnace Maintaining Temperature Erratically
During our camping trip last week, we experienced erratic behavior of the furnace temperature cycling. It really got bad during a particularly windy evening/night. We had the temperature set to 73 degrees and sometimes the furnace would shut off at around that temperature and other times I had to turn the thermostat down to 68 to get it to shut off at 78 degrees or so. The outside temperature was in the low 40's.
The next morning, it was acting similarly, but the wind had died down some. I popped the thermostat off the wall and noticed cold air blowing into the trailer through the hole in the wall for the control wire; this cold air was keeping the thermostat cooler than the inside of the trailer. The thermostat is on the wall with the referigerator on the other side and the wind was blowing into the referigerator ventilation grate and through the hole. So I plugged the hole (allowing the wire to still slip in and out easily) and reinstalled the thermostat and the erratic behavior ceased!! Luckly a simple fix to what I thought was a faulty thermostat.
David
02-06-2012, 09:02 PM
Oswego
When I had my fridge out last summer to replace the cooling unit, I lined the walls of the fridge compartment with reflectix for just this reason (as well as general insulation improvement).
-Rich-
02-06-2012, 10:40 PM
Salem
, Oregon
Hi, although my furnace works good, My thermostat, front thermometer, and rear thermometer didn't match; And they probably shouldn't. I also removed my thermostat and filled the wire hole with foam rubber and taped over it, to prevent what you experienced. My thought, was that hot air from the refrigerator could get in there. If I ever have the need to remove my refrigerator, I will also insulate that wall.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
02-07-2012, 12:01 AM
2005 30' Land Yacht 30 SL
Castro Valley
Robert, Thanks! I've been going mildly nuts (but more than usual) by the furnace overheating the coach, then getting too cold before it kicks on again; too much hysterisis, so I'll check the thermo location and see if I have a similar problem.
Cliff & Andrea,
two snowshoe cats, have not been camping yet
02-07-2012, 01:12 AM
2000 25' Safari
Davidson County
, NC Highlands County, FL
When I changed my original thermostat to a digital I also stopped the draft at the thermostat wire. Now a 1 degree temperature swing inside the trailer will cycle heat on and off. Though the furnace cycles more often than before, it runs shorter cycles and does not over heat. I think it is more fuel efficent now and it is much more comfortable.
Alan
02-07-2012, 01:57 AM
1993 34' Excella
Estancia
, New Mexico
If you have a thermostat with an actuator you can set the low and upper limit the furnace operates eliminating short cycling.
02-07-2012, 02:06 AM
2000 25' Safari
Davidson County
It is not short cycling. Just shorter cycle than before. With the old stat the swing was more like 10 degrees.
Alan
02-07-2012, 07:43 AM
Wise Elder
2010 30' Classic
South of the river
David, I have made this mod as well, also relocating the thermostat slightly so it's not behind the TV.
I have written elsewhere about the problems with the Dometic CCC, which are legion. Among them are that the cycle times for the furnace are too short leading to excess battery consumption when boondocking since the furnace spends as much time running the blower for the pre/post purge part of the cycle as it does with the burner on.
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Furnace Problem
NOAZRK2690 |
Furnaces, Heaters, Fireplaces & Air Conditioning |
10 |
04-10-2014 08:34 AM |
My furnace blows... out its own flame
godaddy64 |
15 |
12-13-2011 08:15 PM |
Furnace Problem
Stone Ridge |
3 |
12-05-2011 06:30 PM |
Duo-therm and furnace question...
NoMoSOBs |
13 |
10-21-2011 09:17 AM |
Need advice on furnace.
SilverRanger |
5 |
05-28-2011 03:47 PM |
