Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 10-04-2009, 08:54 AM   #1
Profile:  1999 25' Safari
Sebastopol , California
Furnace just goes 'Click"
My 84 Excella has a fairly new Suburban heater. It has been working, but now when I turn on the thermostat, I hear the heater just go "Click". The blower does not turn on at all and the heater never starts. Any ideas? Winter is slowly approaching and the autumn already feels cold.
Many thanks,
Ben
Aluminumb is offline   Reply With Quote
Old 10-04-2009, 09:06 AM   #2
Commercial Vendor
Profile:  Corona , California
Many thanks,
Ben
The LPG wil not feed the furnace burner, unless the motor runs. When the motor runs, the air moves a "sail switch" which in turn activates the LPG valve.
For what ever reason, your motor is not running. It could be the relay, it could be a disconnected wire, it could be a bad motor.
Pulling the furnace out for a bench check, should answer the question.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 10-04-2009, 09:41 AM   #3
HowieE's Avatar
Profile:  1991 34' Excella
Princeton , New Jersey
Images: 11
What you hear is the fan relay closing.
You will have to get into the heater and determine why the fan does not come on once the relay closes. There could be something physically holding the fan blades, some have reported mud dubbers, or the fan motor may be open.
Unfortunately you may have to remove the heater to get to the areas in question. Once removed and you have inspected to see if the fan is free to move I would hook 12 volts to the fan motor and see if runs. If the fan is free and runs when powered than work you way back to the fan relay and check for a bad relay.
WBCCI 12156 AIR 3144 WDC unit
1997 6.5 Diesel Chevy 2500 See my pages mysite.verizon.net/vze54tx9/
and mysite.verizon.net/vze54tx9/kayak/
1991 34 ft. Excello +110,000 miles, new laminated flooring, new upholstery, new 3200 lbs axles
Old 10-04-2009, 02:29 PM   #4
Profile:  Natchitoches , Louisiana
.... some have reported mud dubbers.........
That turned out to be my problem. I have a 2008 Airstream with the same symptom, "click and nothing else". Removed the furnace this week, opened it up and found FIVE mud dobber "nests" or whatever those globs of mud are. Got rid of those, the turbine turns fine now.
JD Thornton
Natchitoches Louisiana, the center of wasp universe
jdthor is offline   Reply With Quote
Old 10-04-2009, 03:30 PM   #5
Thank you
All good ideas and suggestions. Thank you. I'll yank it and see why its not spinning.
Ben
Question for "LEWSTER" & others about furnace board catson4 Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-05-2009 08:22 AM
Infamous Suburb.NT-22 "recall" furnace issues! fotochop Furnaces, Heaters, Fireplaces & Air Conditioning 5 01-07-2008 06:50 AM
Furnace "backfires" when hot paddy79 Furnaces, Heaters, Fireplaces & Air Conditioning 6 12-13-2004 09:19 PM
1972 31' w/Propane Furnace "no heat all fan" FarHarley Furnaces, Heaters, Fireplaces & Air Conditioning 4 11-25-2004 09:34 AM
