Old 05-14-2009, 11:07 PM   #1
1974 25' Tradewind
Monument , Colorado
Furnace Issues on 25' Tradewind
Need advice.
When I initially light my pilot and call for heat sometimes the burner fires and sometimes not. Appears something shuts gas off at the pilot. When it does work and cycles, pilot is still on at shut down, but goes out upon refire, fan blows but no heat. I can relight the burner with fan blowing by pushing the piezo and get heat.
Any suggestions?
seeflash is offline   Reply With Quote
Old 05-15-2009, 06:49 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If the furnace is a NT22a you should be aware there is was safety recall on that furnace. I messed around with my original furnace too long. Replace it and save yourself time and hassle.
Old 05-15-2009, 11:42 PM   #3
1974 25' Tradewind
Monument , Colorado
Thanks. It is an N22a but has been serviced recently. Rubber boot on intake is OK plus I have a CO2 sensor inside. Have not had any alarms.
Old 05-16-2009, 05:54 AM   #4
1976 25' Caravanner
Campton , New Hampshire
Sounds like the fan is not operating fast enough to open the sail switch which controls the gas valve. Are you plugged into shore power when this happens ? Is the battery charged ? You also may have a week pilot , try taking the tube off and cleaning . good luck
ticki2 is offline   Reply With Quote
'69 AS Sovereign Furnace Issues Engtech05 Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-16-2009 07:23 AM
1975 25' Tradewind Furnace and Refrigerator Questions craigr Refrigerators 12 08-01-2006 09:18 PM
1987 Sovereign 25' -Any Issues?? nukesul 1984 - 1989 Sovereign 3 04-04-2004 08:29 AM
Safari 25' ss & CCD 25' - odor issues? darkStar Waste Systems, Tanks & Totes 15 09-29-2003 01:28 PM
Safari 25' Model A towing issues rtierney 2003 Safari 11 07-02-2003 10:15 AM
