Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 12-07-2005, 02:29 PM   #1
knjobrien5
knjobrien5's Avatar
Profile:  1969 31' Sovereign
Albuquerque , New Mexico
furnace install
OK this is the third time Ive tried to put these pictures of my install up lets try again...
ID:	16924  Click image for larger version
Name:	side by side 1.jpg
ID:	16926  Click image for larger version
Name:	side by side 2.jpg
knjobrien5 is offline   Reply With Quote
Old 12-07-2005, 02:33 PM   #2
knjobrien5
knjobrien5's Avatar
OK I got it. The new furnace came set up for side discharge. I did not buy the down plenum kit so I covered the side discharges and made my own down discharge.
The New furnace was a NT 30 "SP", the old was a NT-30 "M"
Only apparent differance was the location of the gas line and wiring connections and the fire box seems lighter.
ID:	16928  Click image for larger version
ID:	16930  Click image for larger version
Name:	new installed input side.jpg
Old 12-07-2005, 04:05 PM   #3
knjobrien5
knjobrien5's Avatar
Once I had evrything covered and the down discharge set up the new box fit perfect Where the old one was. I installed the new thermostat that came with the furnace. Does anyone know what the "actuator setting" is supposed to be at. Neither the furnace manual or the thermostat instructions gave me a number. I have test run the furnace and it seems to cycle ok.
Otherwise the install was fairly easy.
Old 12-08-2005, 08:52 AM   #4
3Ms75Argosy
3Ms75Argosy's Avatar
Profile:  1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Maybe fancy speak for....
Isn't that the temperature that you set on the thermostat? (i.e. - if you set it at 70, it'll actuate below 70?)
Marc
Old 12-09-2005, 06:52 AM   #5
loecj76
loecj76's Avatar
Profile:
I set mine at .25. It cycles improperly if you set it higher.
loecj76 is offline   Reply With Quote
Old 12-09-2005, 12:59 PM   #6
knjobrien5
knjobrien5's Avatar
The actuator setting is a "sensitivity" setting a think. It has to do with how long the blower or furnace will run once the thermostat trips.
If its not set correctly the furnace will "short cycle" or turn off before reaching the set temp and then have to turn back on again. The result is the furnace ends up kicking on and off more frequently.
This is to say, that is my understanding of it's purpose. I will start at .25 and go from there.
I am taking her out next month to the mountains of northern NM (Red River), for a working vacation. Teaching a class one day, skiing with the family the next.
Old 12-09-2005, 01:51 PM   #7
markdoane
Profile:  , Minnesota
Images: 59
You may be looking at the 'heat anticipation' setting. Usually you set it at the amperage of the primary control element.
For example, if the gas control valve has a .25 amp control relay, then you would set it at .25. On the other hand, if the control element was a large hot water valve with a big actuator you may need to set it higher.
Let it run at least 24 hours between adjustments, you will find the best setting by trial and error.
Non-contributing deadbeat.
72 Airstream International Furnace parts loechli Furnaces, Heaters, Fireplaces & Air Conditioning 7 08-20-2008 07:17 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
