Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Prev Previous Post   Next Post Next
Old 10-29-2007, 11:18 AM   #1
billberk's Avatar
Profile:  2007 20' Safari SE
Springfield , Missouri
Furnace Ignition Problem
I’m having an intermittent ignition problem with the Atwood furnace in my 2007 Safari. The blower comes on and I can hear the clicking sound of the igniter. It tries to light three times and then gives up.
After I turn the thermostat off and back on, and hit the reset switch on the furnace, it may light and cycle through properly a few times before failing again. I noticed this happening after I ran out of gas in one tank and switched to the other. That may just be coincidence since it had no effect on the water heater.
Has anyone experienced this or have suggestions on how to troubleshoot the issue?
Thanks in advance. -Bill
billberk is offline   Reply With Quote
Suburban Elec Ignition Question Problem. Deano69LY Furnaces, Heaters, Fireplaces & Air Conditioning 2 04-10-2007 01:23 PM
furnace problem nwclassic Furnaces, Heaters, Fireplaces & Air Conditioning 10 01-12-2007 12:15 AM
Furnace Problem Hexhead Furnaces, Heaters, Fireplaces & Air Conditioning 2 10-07-2006 07:49 PM
Furnace problem bbrackman Furnaces, Heaters, Fireplaces & Air Conditioning 22 12-27-2004 09:01 AM
Furnace problem Paul Daugherty Airstream Motorhome Forums 20 02-19-2003 04:31 PM
