01-16-2018, 08:40 PM
1989 25' Excella
breckenridge
Furnace help
I just bought a 1989 excella. I’ve been trying to get the heater to fire up. The fan comes on and I have cycled through the light up instruction. Be heat! I upend the gas line to insure that there is gas to the heater, check. I checked the fuse, it’s good. There is no manual pilot to light.
Help
01-16-2018, 09:29 PM
Living Riveted since 2013
2016 Interstate Lounge Ext
Green Cove Springs
Check to see whether there’s a sail switch in your furnace, and if so, whether it’s working.
01-17-2018, 09:48 AM
1989 25' Excella
breckenridge
Is that the Valve that open and lets gas into the heat chamber?
01-17-2018, 09:52 AM
2007 22' International CCD
Corona
That is a switch that senses proper airflow from the blower, when that switch closes, then the gas valve and ignition comes on.
01-17-2018, 09:57 AM
Green Cove Springs
Heater help
Exactly, and if that switch isn’t working properly, or if your blower isn’t moving enough air, no heat!
01-17-2018, 11:31 AM
Rivet Puller
2003 28' Safari S/O
Atlanta Burbs
, Georgia
Depending on your level of knowledge, using YouTube may expand your ability to diagnose the issue. Try searching YouTube for "RV furnace sail switch" and viewing the clips.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
01-18-2018, 06:45 AM
1989 25' Excella
breckenridge
Is it located under the cabinet with the blower or outside with the heater unit? One other question do you know if the blower recycles the air from inside or is it always pulling fresh air from the outside? My lower is located under the stone and has a removable panel to access. I have three air vents but don’t see a filter or return air duct.
01-18-2018, 07:56 AM
Airstream - Other
Bosque Farms
, New Mexico
Wayne, as a first step, locate the manufacturer and model of your heater. It should be on or near the lid.
Lynn
ACI Big Red Number 21043
01-18-2018, 08:04 AM
1993 34' Excella
Estancia
, New Mexico
The sail switch is not a switch you can manually turn on/off. It is a mechanical/ electronic sensor located inside the furnace.
If the furnace in your excella is basically the same as my 93 it is a Hydroflame and would be fairly easy to remove for repair or replacement without disassembling your trailer to do so.
01-18-2018, 10:51 AM
Green Cove Springs
Furnace help
If you can access the furnace from the outside via the door behind which they are usually installed, this may be your best bet. A sail switch is a “ten dollar part.” The money comes from knowing where it is, how to test it and how to replace it...or so my dealer told me when ours failed. [emoji57]
01-18-2018, 11:32 AM
Airstream - Other
Bosque Farms
, New Mexico
What's kind of interesting is that the sail switch in our old NT30 furnace failed repeatedly. However, the last replacement that I bought had been redesigned with a slightly larger sail. No more failures.
Lynn
01-19-2018, 06:24 AM
1989 25' Excella
breckenridge
It was the sail switch. Fixed! Thanks all
01-19-2018, 08:28 AM
Green Cove Springs
Woot! Congratulations!
01-20-2018, 07:20 PM
1966 20' Globetrotter
johnsoncity
, Tennessee
Sail switch
Did you have to remove the furnace
01-20-2018, 08:03 PM
Airstream - Other
Bosque Farms
, New Mexico
Varies by make and model. Our NT30 does require removal. I've worked on others that did not require it. Of interest, however, is that the NT30, even with removal, was the easier job.
Lynn
01-21-2018, 03:38 AM
johnsoncity
, Tennessee
Thank Eubank for your reply. Will check model number. Been to cold (2 degrees) in the Tn mountains to get much done. Thanks. My trailer is a 85 model
01-22-2018, 02:55 PM
Airstream - Other
Bosque Farms
, New Mexico
By make and model, I mean the make and model of the furnance, not of the Airstream. On older rigs, many have had appliances swapped out.
LYnn
01-25-2018, 03:07 PM
johnsoncity
, Tennessee
Furnace model.
My furnace is a NT 30 S sorry it took so long. After looking at it I think I will have to pull the furnace. Thanks for the help
01-26-2018, 10:46 AM
Airstream - Other
Bosque Farms
, New Mexico
Yep, on that model, the sail switch is accessible only from the back side of the furnace.
To remove, disconnect wiring and gas. Unscrew from the floor. Remove the screw from the outside vent. Pull it out.
I replaced the sail switch so often on ours that I finally bought some ultility trailer hitch wiring connector and used it as a quick connect for the furance's main wiring.
Lynn
01-27-2018, 03:30 AM
johnsoncity
, Tennessee
Thanks for the help Eubank
Where did you purchase the upgraded sail switch
Trailer wires was a great idea. Thanks again
DON
