Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 09-26-2002, 03:32 PM   #1
niftypkg's Avatar
Profile:  1971 27' Overlander
Cornville , Arizona
Furnace Exhaust
How to keep rainwater out of Furnace exhaust?? Is it worth the effort ?? Would'nt traveling down the road in a rainstorm cause a lot of water to enter the exhaust and intake plate?? I've never seen it covered nor have I covered mine. Any thoughts??
Tom
There is Something Worse than Dying--- That is NOT LIVING !!!
PERFECT Trailer- Dog loves it- Wife hates it!!! You're not camping until you're miserable!
niftypkg is offline   Reply With Quote
Old 09-26-2002, 03:42 PM   #2
uwe
418
uwe's Avatar
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Portola Hills , California
Images: 41
Hi Tom,
I've never seen any of these little covers protected from rain. Maybe the inside design prevents water from entering. I have seen some of the furnace exhausts having protective lids, but that's so no one would touch the hot exhaust.
I have never seen water enter the vent, not even when washing the trailer with a hose.
Uwe
www.area63productions.com
Old 09-26-2002, 07:21 PM   #3
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay , Florida
Images: 21
Tom,
Good question. I have deinstalled a couple of the furnaces and the plate that the chrome cover sits over is made as an assembly. They are 4-6 inches in length. The intake and exaust tubes insert into the corresponding tubes in the furnace. I have not gotten out a level to check, but I bet if you could you would find that those openings are tipped down so water will run out by gravity. This would be caused by where the vent is cut in the skin, or by mounting the furnace up a bit in relation to the holes. If you think about it it is a simply elegant way to keep from obstucting the intake/exaust. When the unit is running I bet there is enough heat to keep it all dry!
BTW Suburban says that if you add ANY type of cover or screen to their furnace exaust, even to keep out the wasps and mud daubers you will void your warranty. So be sure to take it off before you take the unit in for service!
Brett G
WBCCI #5501 AIR # 49
Logic is the one way you can go wrong with confidence - Charles E. Kettering
Old 09-27-2002, 10:19 AM   #4
niftypkg's Avatar
Cornville , Arizona
Exhaust Plate
thenewkid, I managed to get a new [used] plate to replace the corroded original. So the original configuration is different! I'll take another look to check it out. Tom
Furnace sets off smoke alarm silverback 2003 International CCD 37 11-12-2006 09:24 PM
The exhaust manifolds are off! Now what? swebster Mechanics Corner - Engines, Transmission & More... 13 08-07-2005 01:29 PM
Surburban Furnace Ills - HELP Cat Furnaces, Heaters, Fireplaces & Air Conditioning 22 07-07-2005 08:22 AM
R & R a Suburban Furnace Janet's Husband Furnaces, Heaters, Fireplaces & Air Conditioning 3 06-24-2004 08:19 PM
Furnace exhaust smell Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-25-2003 08:54 PM
