Greetings from the Florida Panhandle
We have been avid Airstreamers and members here at AirForums for about thirteen years now. I do not ever recall seeing a thread that mentions cleaning the furnace ducts. Most of our cold weather camping has involved using the heat pump. When we have used the gas furnace, we have always noticed a distinct odor when the furnace is first started. it is most likely from the dust that has built up in the ducting between uses.
The only way that I can think of to clean out the furnace ducts would be to get one of those long tube plastic hoses that hooks to a shop vacuum that is used to clean out clothes dryer vents. You could remove the furnace vent registers, and go up each one as far as the hose will reach.
Other that that, you might try a Google search and see what you come up with. Also, along this same line, the search function on the Forums is not very good. It is always best to Google "airforums" and the subject that you are trying to find. This will most often work better.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
