Old 01-12-2009, 07:14 PM   #1
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Furnace cover
Received in the mail from Frank a furnace cover for the 63, but not sure how this was supposed to bolt up. I gather from marks on the metal frame that I have it layed out, but not sure what the brackets are for, nor how they mount. Also wondering how the chimney like unit bolted up.
I've searched for threads showing an install on this, saw Bowen water heater doors, but nothing on this one. Can anyone point me in the right direction?
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-12-2009, 07:35 PM   #2
dreadydreame's Avatar
1965 26' Overlander
Newport , North Carolina
tomorrow I will take some photos of how mine looks without the cover on, and the back of the cover, you can maybe see from that how you could make it work, although mine is not a refit to a new furnace, we still have the old one in place.
,Katie & Anthony, 2kids, lots of pets!
dreadydreame is offline   Reply With Quote
Old 01-12-2009, 09:20 PM   #3
VIKING's Avatar
Boulder Creek , California
The shroud fits over a vent that projects from the side of the trailer. It drops down onto the vent and there are two screws to secure it that go in from the sides, near the bottom. They go in at a slight angle.
The plate that mine is attached to is a single piece, not the same as the parts in your picture, but the final attachment is the same. If you look at the back of your shroud you should see the two tabs with holes for the screws. I don't have my camera with me, or I would get a couple of close-ups for you. If you still need more info tomorrow evening I will get them to you. Here's a straight-on shot I had already downloaded
Good luck, Rich
P.S. I almost traded my '64 safari for the safari you are working on. It wouldn't have been a good trade for me at the time. I'm glad you ended up with it.
Rich
Name:	'64 SAFARI 031.jpg
VIKING is offline   Reply With Quote
Old 01-12-2009, 09:20 PM   #4
goransons's Avatar
1963 22' Safari
Thank you guys, I appreciate any photos. It will be going over a suburban furnace so hopefully there won't be too much modification but I guess we'll see! The tabs on this one are a bit chewed up but I think I can make it work. Did the original furnace have intake/exhaust horizontally versus verticle like the modern suburbans?
- Scott
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 01-12-2009, 09:25 PM   #5
goransons's Avatar
1963 22' Safari
this is what I need to tuck behind it (borrowing the photo). Of course it mounts up and down, not sideways as shown here. Viking does you removable panel have any drip cap over it or anything? Also, we're glad we ended up with it too =) If it didn't have the history it wouldn't have been a good trade for us, we were just to the fun part (all wiring was new, new insulation throughout, new rear floor, new window weatherstrips, repaired door and frame, rebuilt step) but we're not complaining. We're happy how it turned out.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 01-12-2009, 09:32 PM   #6
VIKING's Avatar
It's vertical. but I think the screws go into the furnace itself, so you may need to modify the attachment to work with your suburban. It shouldn't be very difficult though. Probably just a couple of tabs screwed to the front of the piece in your picture.
Rich
Old 01-12-2009, 09:40 PM   #7
goransons's Avatar
1963 22' Safari
Here's the back, both horizontal slots. May have to modify the back some.
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 01-12-2009, 10:02 PM   #8
VIKING's Avatar
By vertical I meant the inlet is below the outlet, rather than side by side. You're right, the back will need some work....
Old 01-13-2009, 09:59 AM   #9
VIKING's Avatar
There's no drip cap on the furnace vent. The original vent sticks into the shroud and the shroud keeps the water out by its design. I'll post some pics tonight.
Rich
Old 01-13-2009, 08:11 PM   #10
VIKING's Avatar
furnace cover attachment
Hi goransons,
Here are a few pics of my furnace cover and the attaching location. If you need any more detailed shots let me know.
Good luck, Rich
ID:	73898   Click image for larger version
ID:	73900   Click image for larger version
Old 01-13-2009, 10:10 PM   #11
goransons's Avatar
1963 22' Safari
Ok that makes a lot more sense. I guess I need to get the plywood in this section then reinstall the furnace, and see how I can align things. I'll have to modify this cover, I just hope there is enough air flow with the venting relocated, but would imagine it should be ok. Thanks again for taking the time to pull that apart and snap photos!
- Scott
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 01-14-2009, 12:21 AM   #12
VIKING's Avatar
I needed to take it off soon anyway, so I'm glad it was some help.
I'll be stripping the rest of my interior out this weekend, furnace included, so now I'll have one less thing to do saturday morning.
I don't know how similar these safaris are from '63 to '64, but I'm taking lots of pictures as I dismantle mine. If you need pics of anything for your documentation let me know. My trailer is almost bone-stock '64 vintage & I'm sure there is some overlap in these two years.
Good luck, Rich
Old 01-14-2009, 07:37 AM   #13
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
I know these pictures are of the water heater, and not the furnace, but check out the hinged door modifcation during the refurbishment. Might this have an application for the furnace as well? I like the idea of being able to get to more of the hot water heater and/or furnace from the outside. This work was performed by Vintage Campers in Indiana.
ID:	73943   Click image for larger version
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 01-17-2009, 05:57 PM   #14
1965 26' Overlander
Is the water heater above an atwood? we are needing to buy a new one and want to keep the old cover, just wondered if this is atwood.
'61 Overlander furnace cover wildcat455 1960 - 1964 Overlander 13 03-03-2009 08:27 PM
To cover or not to cover vents? Director 1965 Overlander 4 10-28-2007 07:01 PM
RV Cover LeeMo Off Topic Forum 10 07-21-2004 05:01 PM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 10:54 AM
