Old 02-03-2009, 10:47 PM   #29
VIKING's Avatar
Boulder Creek , California
It's aluminum mesh. are you missing the whole thing or just the mesh part?
The photos show how it's formed at the corners, cut from a single piece, and bent to shape. There are tabs left on the back side that fit into slots in the sheet aluminum and are then bent over to secure it in place.
This is from my '64 Safari.
Good luck to you!
Name:	W H SHROUD 002.jpg
ID:	75038   Click image for larger version
Name:	W H SHROUD 006.jpg
Name:	W H SHROUD 003.jpg
VIKING is offline   Reply With Quote
Old 02-04-2009, 06:24 AM   #30
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Good luck to you!
Thank you for this documentation. I am missing the exact same piece! It looks like it can be easily fabricated, assuming the correct virgin material. This must have been an easy piece to lose.
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 02-05-2009, 11:01 AM   #31
1966 26' Overlander
San Luis Obispo , California
Thank you very much! That is exactly what I needed.
slofoks is offline   Reply With Quote
Old 02-05-2009, 11:24 AM   #32
VIKING's Avatar
You are both very welcome. if you want dimensions or anything, just let me know. I have everything apart right now and it's easy to get to.
Rich
Old 02-06-2009, 06:38 AM   #33
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Rich
Rich:
Yes, please! I was hoping your drafting side might offer this up! Not sure yet where or how it will get made, but this will be critical to getting it done. Much appreciated!
-Tim
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 02-06-2009, 01:06 PM   #34
VIKING's Avatar
I'll get that to you tonight Tim.
You will make this yourself, in about twenty minutes, with a set of metal cutting shears. It's really simple, like cutting out a piece of paper.
Have a good day, Rich
Old 02-06-2009, 10:40 PM   #35
VIKING's Avatar
Water heater shroud
The size of these may have changed some with different years and models of W H's. Check before you cut!
To form the final shape you can bend the radius' with a broom handle and some elbow grease, and the bottom fold is a sharp bend, use a framing square or a square edged piece of wood to make a 90 degree bend. then it's just a matter of getting the tabs into the slots, one of my favorite games!
ID:	75157   Click image for larger version
Name:	W H SHROUD 007.jpg
Old 02-07-2009, 12:56 AM   #36
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Rich:
This is just perfect. Thanks for taking the time to draw and measure it all out. I will start looking for the material right away. I think I will start with the hardware store. Thanks again!
-Tim
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 02-14-2010, 10:04 AM   #37
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Originally Posted by goransons View Post
Ok that makes a lot more sense. I guess I need to get the plywood in this section then reinstall the furnace, and see how I can align things. I'll have to modify this cover, I just hope there is enough air flow with the venting relocated, but would imagine it should be ok. Thanks again for taking the time to pull that apart and snap photos!
- Scott
Hi Scott
That is what I did....and it has worked over the last five years. This is the only photo of the furnace revent, but shows the new Suburban vent and the opening cut out of the back of shroud.
What you cannot see is a diverter wing inside of the shroud that help direct the vented exhaust two directions, and also protect the exterior metal from being damaged or discolored from the direct heat.
Name:	furnace Vent 001.jpg
safari62 is offline   Reply With Quote
'61 Overlander furnace cover wildcat455 1960 - 1964 Overlander 13 03-03-2009 08:27 PM
To cover or not to cover vents? Director 1965 Overlander 4 10-28-2007 07:01 PM
RV Cover LeeMo Off Topic Forum 10 07-21-2004 05:01 PM
Need Suburban Furnace Cover For 79/31' Soverign montanaandy Furnaces, Heaters, Fireplaces & Air Conditioning 0 07-29-2002 10:54 AM
