Old 12-15-2019, 09:03 AM   #1
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Furnace Cold Air Return
In reviewing the installation manual on the airstream furnace, I noticed the requirements for 1/2 inch clearance from all materials and basic balancing of hot air exhaust. There is also a requirement for the use of only 4 inch duct work. The cold air return is not addressed; is this because the furnace is a sealed unit?
Additionally, has anyone ever successfully used 4 inch louver controlled exhaust at the end of the duct run?
The furnace is in a flying cloud 27 front bedroom.
Cispook is offline   Reply With Quote
Old 12-15-2019, 10:44 AM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
In my opinion, you don't want to restrict the air flow with louvers as the furnace might overheat. The flame is producing a constant amount of heat that must be carried away by the air flow to avoid damaging the furnace (or worse, starting a fire).
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 12-15-2019, 12:41 PM   #3
Cispook's Avatar
Chillicothe , Ohio
Al
I donít see the rational of two runs of duct ... one blows 75% of the heat under the dinette table and the remaining run is furthest to delivery and barely has an air flow.
There are no obvious obstructions ... in a forced air environment such as a home there would be duct balancing using louvers or in line duct work louver.
Old 12-16-2019, 03:45 PM   #4
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Lots of posts on this if you use the search function. Here is one I just found with Airforums Search. http://www.airforums.com/forums/f44/...ow-162159.html
The solutions are not necessarily as straight forward as one might think.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 12-16-2019, 04:20 PM   #5
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
If your 27FB is like my 2013 25FB, the cold air return has no duct, it just sucks air in from the interior of the trailer through the arch-shaped opening in the streetside bench.
My furnace pumps air out through four ducts: to the dinette, to the closet/hallway area, to the bedroom, and into the floor through a hole right next to the furnace. One of the ducts going forward has a tee that feeds a smaller flex hose that runs across to the bathroom.
SSquared is offline   Reply With Quote
Old 12-16-2019, 04:32 PM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
On my 2014 25' rear bedroom twin, the furnace pumps most of the heat to the dinette as that is closest to the furnace. I blocked off about half of that vent to push more heat to the rear of the trailer. It seems to work well with no problems for 5 years.
2019 Ford Expedition Platinum
Old 12-16-2019, 05:53 PM   #7
Al
I mentioned louvers because OP asked bout using a louvered vent at the end of a duct run. I think one would have to be careful to ensure adequate air flow.
Al
S/OS #004
Old 12-17-2019, 07:33 PM   #8
Cispook's Avatar
Chillicothe , Ohio
Lots to consider. I had read numerous links on the issue.
IMHO the bigger issue is the placement of the furnace in the FB model. In a perfect set up the furnace would be centered in the AS thereby ensuring a better balance of heat distribution.
When I take on my remind next year Iíll have a better understanding of the approach I will take in furnace ductwork and flow.
Much appreciative of the input.
Old 12-17-2019, 07:54 PM   #9
dznf0g's Avatar
Oswego , Illinois
The furnace must have the prescribed exit ducts as listed in the manual. Pretty sure yours is four 4" ducts. I ran a fifth to the rear of the trailer and added a register which closes one of the two in the living room. A much better balance.
-Rich-
Old 12-17-2019, 08:44 PM   #10
dznf0g's Avatar
Oswego , Illinois
Search for a thread called, "not enough heat in the back" for a thorough discussion.
-Rich-
Old 12-18-2019, 06:04 AM   #11
Cispook's Avatar
Chillicothe , Ohio
Return air to furnace blower. CurtH93 Furnaces, Heaters, Fireplaces & Air Conditioning 0 04-04-2016 11:57 AM
furnace blowing cold air canine camp Furnaces, Heaters, Fireplaces & Air Conditioning 55 07-27-2013 12:14 AM
furnace blows cold air only 99Limited34 Furnaces, Heaters, Fireplaces & Air Conditioning 11 05-08-2010 09:49 PM
Return Air? Chip Arnold Furnaces, Heaters, Fireplaces & Air Conditioning 7 11-21-2008 04:36 PM
Furnace blows cold air guy99 Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-06-2007 11:26 PM
