Old 11-09-2006, 12:30 PM   #1
kamo's Avatar
burbank , California
furnace chimney seal
I removed the furnace chimney from my '62 Bambi. It looks like they used something very similar to plumber's putty between the chimney and the side of the trailer as a seal.
Does anyone know what thias material is? Maybe I can use some fiberglass instead?
Kamo
kamo is offline   Reply With Quote
Old 11-09-2006, 01:08 PM   #2
Fyrzowt's Avatar
West of Fort Worth , Texas
Images: 8
Most likely it's a caulking tape available at RV stores and home centers. It comes in a roll of tape, usually 1/2" or so in width. There are variations of sizes.
Fyrzowt is offline   Reply With Quote
Old 11-09-2006, 04:17 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
A great gasket material is shower pan liner - sold by the linear foot at home centers. You could trace your needed gasket and cut it from this material. It's been called an environmentalist's nightmare because it never seems to deteriorate - just the kind of material that's great for AS repair. It's also grey so the color doesn't stick out against the skin.
Old 11-09-2006, 06:24 PM   #4
kamo's Avatar
Will the liner work with the heat produced by the chimney?
Old 11-10-2006, 09:22 PM   #5
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Given the material I'd think so but can't guarantee that.
Old 11-25-2006, 08:36 PM   #6
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Tested the material at 400 degrees - no failure.
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
Jingle Bell Furnace Fix Pahaska Furnaces, Heaters, Fireplaces & Air Conditioning 5 11-19-2002 09:59 PM
Forced Air furnace Joan D'Andrea Furnaces, Heaters, Fireplaces & Air Conditioning 16 11-02-2002 09:41 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 08:29 PM
