Old 08-14-2011, 06:36 PM   #1
StPierre's Avatar
1965 22' Safari
Rescue , California
Furnace change in a 65 Safari
We are thinking of removing the original furnace on our 65 Safari and installing an Olympian Catalytic Wave Heater. Has anyone done this? If so, how is this working, and do you have any advise? My one concern is condensation inside the trailer.
The St Pierre's
StPierre is offline   Reply With Quote
Old 08-19-2011, 02:04 AM   #2
worldinchaos's Avatar
1959 17' Pacer
Long Beach , California
I'm surprised no one has responded yet, but basically you are going to get two big sides on this, the "if you properly vent your heater, then it is not an issue" side, and the "oh my dear lord why would you ever do that it is your life do what you want side".
As with everything, there are risks to it, and as long as you know enough about the systems to safely mitigate those risks by providing proper combustion air sources and fresh air to replace it, then you will be OK. However, failure to do so can be very bad.
For the record, I plan to do it. But that's still a ways away for me
Just do a search on "catalytic heaters" in the heater section and you'll find some good comparison threads.
- Peter (and Marie)
TAC CA-15
1959 Pacer 18' Renovation - Knight in Shining Armor
Our Adventure Blog - Documenting our backpacking, hiking, camping, and Airstreaming
(still updating, haven't gotten to the Airstream trips yet)
worldinchaos is offline   Reply With Quote
Old 08-19-2011, 08:05 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Condensation should not be an issue with a CAT heater as long as you keep a window open. While CAT heaters do not normally produce CO, it is still a good idea to have a CO detector. CAT heaters do consume the Oxygen out of the air. Operating them without an open window or vent can be dangerous. Some CAT heaters do have an Oxygen sensor that shut the unit down if the Oxygen level get low, but an open vent or window is still a good idea.
We have a CAT in our trailer as well as a furnace. We use the CAT to take the chill out of the trailer in the mornings when we are off the grid. We never go to bed with the CAT on.
Richard
Old 08-19-2011, 08:20 AM   #4
Patriotic
Chuck's Avatar
1973 23' Safari
Images: 260
good idea? I'd say "mandatory", with any gas-burning appliance...which means you need one anyway, if you're burning gas for fridge/stove/hot water...or a conventional furnace...none of which "normally" add CO to the cabin; its when they're acting "ABnormal" that we're worried about.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 08-19-2011, 08:24 AM   #5
2002 25' Safari
Dewey , Arizona
Images: 62
I agree, mandatory...
Richard
Old 08-22-2011, 09:32 PM   #6
StPierre's Avatar
1965 22' Safari
Rescue , California
Thanks for the advise. The pros as I see it are more storage under the sink, don't have to figure a new duct system, less propane use, it's quiet. The cons are that I have to patch the exterior skin where the original furnace was, (which is the biggest problem). I agree with the CO detector, that is a must.
The St Pierre's
New Safari owner 2001sport 1966 - 1968 Safari 10 06-24-2011 11:30 AM
Need advice on furnace. SilverRanger Furnaces, Heaters, Fireplaces & Air Conditioning 5 05-28-2011 03:47 PM
Removing International Furnace from 1965 Safari miscwires Furnaces, Heaters, Fireplaces & Air Conditioning 2 03-17-2011 05:10 AM
Furnace Noise azflycaster Furnaces, Heaters, Fireplaces & Air Conditioning 12 03-06-2011 11:36 AM
