Old 10-18-2010, 06:31 PM   #1
Renton , Washington
Furnace capacitor replacement NT 32A
Wire broke on positive side of furnace capacitor at base. No way to solder wire on it without damage. Called and went to numerous places with no good news so far.
Has anyone found a replacement capacitor for Suburban NT32 on a 72 overlander ?
Marking on the capacitor show :
"Callins"
7136
11-65psd750-50s
750mF-50v
Need furnace for the winter.
Bambi517 is offline   Reply With Quote
Old 10-18-2010, 08:41 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
CORNELL DUBILIER|CG801U050R2C|CAPACITOR ALUM ELECT 800UF, 50V | Newark.com
Check the dimensions and be sure it will fit, the size and shape may differ a little. That one has screw terminals for ease of installation. They have 31 in stock and ship the same day you call. It's a $17 part.
Any of the other large electronics distributors should have them, too.
Old 10-18-2010, 08:48 PM   #3
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Try this
"Callins"
7136
11-65psd750-50s
750mF-50v
I can not find a capacitor on any Suburban schematic I have found. If the cap is wired across the motor it is a bypass capacitor and it is used for filtering noise, keeping it from the DC supply. Keeps the radio static free when the fan starts.
Never seen a DC starting cap but if you need one this should work just fine, if the size is ok.
Aluminum Electrolytic Capacitors - Screw Terminal
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 10-18-2010, 09:02 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I just looked at the 75 service manual and I do not see a cap in the NT 32 circuit or any other furnace circuits that year.
Richard
Old 10-18-2010, 09:19 PM   #5
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
an old post from Chuck, here - http://www.airforums.com/forums/f427...tml#post180676
has a Suburban manual posted (for perhaps a product similar to your NT-32A) that describes item # 29A, p/n 230327, as a "Capacitor, 750MFD Electrolytic" on pages 22 & 16.
(the scanned doc has pages 2 to 24 scanned in reverse order! but they're all there!)
I'd try a Suburban dealer / service center first - Airxcel | Suburban Manufacturing Service
failing that, I'd agree with Janet's Husband, Gary, that it's just a filter cap that you should be able to get from a motor or generator shop, or Grainger, or Mouser, etc.
good luck!
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 10-18-2010, 09:31 PM   #6
2002 25' Safari
Dewey , Arizona
Images: 62
Interesting that Airstream did not include the cap in their documentation...
Richard
Old 10-18-2010, 11:18 PM   #7
Wise Elder
Jammer's Avatar
2010 30' Classic
It's on the schematic linked from post #5 above and is wired as a bypass cap for the fan motor.
Its purpose then would be to reduce the interference to radio systems, particularly broadcast a.m. radio. You can leave it out of the circuit entirely, or replace it with a capacitor of even roughly similar rating. In fact, a 750 uF capacitor is extremely large for that purpose and probably unnecessary. Also, you can use a lower voltage rating, down to 18 volts, and save some space and money. A 470 uF, 18 volt capacitor is small and should be more than sufficient.
Old 10-19-2010, 12:25 PM   #8
Renton , Washington
Love you !
Is it possibly a run capacitor ?
Will definitely try replacing capacitor as I've been told I would need to replace whole furnace!
Thanks again and will let you know how it works out.
Old 10-19-2010, 12:50 PM   #9
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
Question
anything is possible....
icocbw, but I'm thinking that it's not a run capacitor.
if its a filter cap and not a run cap, the furnace blower should work with the cap disconnected. does it?
when you pulled the cover, is there a schematic drawing on the inside or outside the furnace cabinet?
or, how about a picture or two showing the capacitor and what & where it is connected to?
those hints could be telling, since none of us out here can see what you can see there.
best,
Joseph & Gabrielle
Old 11-03-2010, 11:09 AM   #10
Renton , Washington
Furnace Capacitor for NT 32A Suburban furnace/ UPDATE
Thanks to all your input !
I found an exact match (750uf 50v) for the furnace capacitor at Apex Electronics. It was also 50 cents. I was priced $12 to $126 for others that were not Axial or the right microfarad..etc .Received it Monday, but have the belly skin and gas lines disconnected to clean rust off the frame. Luckily just surface rust. Any body used "Ospho" rust remover before ?
Really nice lady at local Hvac company told me about Apex. There is a minimum $10 purchase, but they also sell 30A plugs for my electrical cord. That was $10. Will let you know about the furnace when I have the gas lines hooked up.
Help, replacement furnace? knjobrien5 Furnaces, Heaters, Fireplaces & Air Conditioning 22 04-18-2018 01:23 PM
Furnace replacement with fireplace? kdenault Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-09-2006 09:17 PM
Furnace replacement...again walter1 Furnaces, Heaters, Fireplaces & Air Conditioning 16 12-22-2004 06:53 AM
Furnace Replacement RiskIt Furnaces, Heaters, Fireplaces & Air Conditioning 13 10-16-2004 01:50 AM
furnace replacement joecj76 Furnaces, Heaters, Fireplaces & Air Conditioning 4 02-18-2004 10:38 AM
