10-03-2007, 07:58 AM
#21
1973 31' Sovereign
Danielsville
, Georgia
10-03-2007, 12:37 PM
#22
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County
, New Hampshire
Originally Posted by PizzaChop
Now I understand.
I'll do some pics of it in place.
I do seem to have an extra heat duct??? 2 that head towards the back, the only outlet visible is the one in the rear beedroom... The other goes to????
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
10-03-2007, 01:01 PM
#23
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
tanks?
(to keep them from freezing)
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
10-03-2007, 01:12 PM
#24
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Originally Posted by Chuck
tanks?
That's what I was thinking it was for, or maybe a heated floor
www.balrgn.com
10-03-2007, 03:33 PM
#25
1976 25' Caravanner
Campton
, New Hampshire
What made you decide on the hydro-flame instead of the NT?
10-03-2007, 03:47 PM
#26
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
$$$ $300 + less
And I wanted to get a more compact unit.
www.balrgn.com
10-05-2007, 04:35 AM
#27
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Retro fit
All ready to install.
www.balrgn.com
10-05-2007, 04:38 AM
#28
2005 25' Classic
Pelham
, New Hampshire
Yikes! Looks like a robot!
Bob & Carla 05 classic 25' WBCCI # 1836
10-05-2007, 06:51 AM
#29
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
tanks?
Nope, the tow flex ducts go to a common metal header, the tank line comes off the metal duct, under the bathroom sink. It is just a 2 into one, for more flow. I will delete one line
www.balrgn.com
10-05-2007, 08:46 AM
#30
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
For those interested, here is the link to the installation, 75% done, still need to fabricate some duct to feed front living area outlet.
1974 Overlander
Ran the furnace for an hours to test, bumped the heat up to check the thermostat. Works nice, very quiet as well! The original was way less than quiet! More like a dull roar.
www.balrgn.com
10-05-2007, 10:17 AM
#31
1976 25' Caravanner
Campton
, New Hampshire
That might cause too much air restriction and sail switch may not open. Worth watching . Then again it may work fine with the smaller furnace.
10-05-2007, 10:54 AM
#32
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Ran it all morning, I think it will be fine, I am using a Tee to pass heat to the living area and back to the bedroom. Works slick, wish it was colder out to give it a good test, had it @ 80 with the Temp 55º outside. Starts and stops fine. The best thing is you can barely hear it in the bedroom!
Oh yeah, all the heat ducts are now hooked in, good flow to everywhere.
www.balrgn.com
10-05-2007, 10:58 AM
#33
1976 25' Caravanner
Campton
, New Hampshire
Sounds good . Don't ya just love when things come together like that.
10-05-2007, 11:09 AM
#34
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
And ta think, I was gonna rebuild the ole one..
www.balrgn.com
10-08-2007, 12:42 PM
#35
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
All installed, check out the full story
Furnace Upgrade
www.balrgn.com
10-08-2007, 02:01 PM
#36
1976 25' Caravanner
Campton
, New Hampshire
Nice job , just in time for fall camping.
10-08-2007, 02:17 PM
#37
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Thanks, wish I could go out this weekend
www.balrgn.com
10-10-2007, 07:58 AM
#38
Naples
Just a quick note in the install of a furnace. Every install manual comes with a specific requirement for ducting area measured in square inches. this is a MINIMUM requiremet to prevent overheating of the unit.
Just be sure that the duct openings at the furnace meet or exceed this number and you're good to go!
lewster
10-10-2007, 09:28 AM
#39
1974 27' Overlander
1960 26' Overlander
Rockingham County
, New Hampshire
Good Point, and yes they do
2 - 4" ducts exit the unit. I may add a 2" line to help flow to the tank warming lines.
As of now the front temp runs about 3 degrees warmer than in the rear, which is perfect for us!
www.balrgn.com
