Old 05-08-2010, 06:11 PM   #1
99Limited34's Avatar
1999 34' Limited
Darien , Wisconsin
furnace blows cold air only
Not sure why but all we're getting is cold air, have plenty of propane and all other thinga gas work fine.......Any ideas?
1999 Airstream 34' Limited (The Cottage)
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
99Limited34 is offline   Reply With Quote
Old 05-08-2010, 06:29 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Is it a Suburban furnace?
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 05-08-2010, 06:39 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have recently had the gas line off the tanks you may have a slug of air in the line to the heater. All the other appliances will purge themselves but the pilot line on the furnace is very small. What I do under this condition is crack the gas line at the heater till you smell gas. Tighten the line and retry to light the heater.
if this fails you may have a bad sail switch or control board but my money is on the gas.
2004 Excursion 4x4
Old 05-08-2010, 06:59 PM   #4
1999 34' Limited
Darien , Wisconsin
I don't think it's air in the line... The furnace was working great this morning....
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
Old 05-08-2010, 07:04 PM   #5
Mike Leary's Avatar
Images: 11
Is it a Suburban? Wait a minute, I already asked that question.
Old 05-08-2010, 07:12 PM   #6
1999 34' Limited
Darien , Wisconsin
I have no idea if it's a Suburban or whatever.......It's whatever they put in a 99 34' limited....How can you tell?
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
Old 05-08-2010, 07:29 PM   #7
Mike Leary's Avatar
Images: 11
Did not mean to get your dander up, just a innocent question. Take a look at the furnace, you should see some kind of i.d. there that would help us help you.
Old 05-08-2010, 07:39 PM   #8
1999 34' Limited
Darien , Wisconsin
My dander isn't up at all......It's a hydro flame, made by Atwood.....
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
Old 05-08-2010, 08:13 PM   #9
1987 29' Sovereign
Sparta , Tennessee
Send a message via Yahoo to wingfoot321
After the furnace has set for a while.
(1) Raise thermostat arm until the anticipator clicks
(2) Blower should come on for 30sec-1min to purge gas
(3) Listen for ignitor to spark
(4) Allow 1 minute for heat to warm the air
If no heat after a minute or so
(5) Take the wood cover off the front of furnace cabinet
(6) Put an electric heater blowing on the front of the heater for a half hour or so. Especially if it has been cool & damp.
(7) Go back and try the start procedure.
If if ignites after warming the unit, I would suspect the electronic board needs to be changed.
If it does not ignite, I would suspect the gas control valve.
Either part is $100 or more & $75-100 to have a service man change out.
I have been throught this process with a suburban 30 that is a littlle older than yours but, I should have just installed a new furnace at the beginning.
wingfoot321 is offline   Reply With Quote
Old 05-08-2010, 08:17 PM   #10
richinny's Avatar
2011 34' Classic
do you have gas at the stove burners?
Ricky
Old 05-08-2010, 08:48 PM   #11
1999 34' Limited
Darien , Wisconsin
I do have gas at the stove burners and the water heater works as well on gas
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
Old 05-08-2010, 08:49 PM   #12
1999 34' Limited
Darien , Wisconsin
Thanks for the reply, I'll give this a try tomorrow.....
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
furnace blowing cold air canine camp Furnaces, Heaters, Fireplaces & Air Conditioning 55 07-26-2013 11:14 PM
Heater turning to cold air in middle of night zenarmy Furnaces, Heaters, Fireplaces & Air Conditioning 6 05-04-2012 10:49 PM
drafts..cold air katsix Member Introductions 13 12-14-2007 10:56 AM
Furnace blows cold air guy99 Furnaces, Heaters, Fireplaces & Air Conditioning 37 04-06-2007 10:26 PM
cold weather how do air streams do? overlander Our Community 2 10-02-2002 05:10 AM
