Hi all, we have a suburban furnace with electronic ignition. Until this morning it was working fine. This morning the blower works (blows cold air) but apparently the burner is not lighting - there is no heat either from the vents or outside at the vent/intake.
Any suggestions about what has failed?
I have had a little problem with the thermostat but I assume that if the blower is running, the thermostat is functioning (the thermostat has 2 wires to it).
1984 310 Limited Motorhome
when mine did that, the propane tank was empty and the blower would not go off, so unplugged power and switched tanks, then plugged back in and all worked fine. hope your fix is that easy (well...easy after i figured it out!)
Sail switches also fail, especially in somewhat dustier environments, and usually result in just the kind of symtom that you describe. Sail switches are relatively cheap to buy, but somewhat more difficult to install. What we've found is that the old sail switch can generally just be blown out well with compressed air and expected to live until the next time around. (Our new spare sail switch has been sitting in its original box now for several years!)
Lynn
Consider yourself lucky, summer will be here soon and you will want the cool air it is providing.
