Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Interior Restoration Forum > Furnaces, Heaters, Fireplaces & Air Conditioning
Old 05-03-2008, 09:05 AM   #1
Lumatic
Lumatic's Avatar
Profile:  1971 25' Tradewind
1962 28' Ambassador
Estancia , New Mexico
Furnace Blower Noise
Noise has been increasing on my NT30. First was just a squeak when the blower came on. Last time I fired it up was a steady grind. I suspect worn bearings somewhere connected with the motor and/or blower. After I pull the furnace, then what?
Are birds ever free from the chains of the skyway? BD
Old 05-03-2008, 10:03 AM   #2
Happycampers
Happycampers's Avatar
Profile:  1979 30' Argosy
Peterborough, , Ontario
Replace it with a new one. That is what I did. It is over 30 yrs. old and if you put a new motor in it, next month or next year you will be replacing something else on it and the list goes on and on.
Marvin
Marvin & Annie
Toby & Niki (fur babies)
1979 Argosy 30
WBCCI 10103
2005 F250 Lariat Power Stroke Diesel Crew Cab 2wd
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 05-03-2008, 12:14 PM   #3
Lumatic
Lumatic's Avatar
1962 28' Ambassador
Marvin
It is a relatively new one, but not new enough for a warranty.
Old 05-03-2008, 02:22 PM   #4
Happycampers
In that case replace the motor, I think they are sealed bearing and the motor is pretty expencive like over $100.00. Most any rv supply place will have one or can get one for you.
Marvin
Marvin & Annie
1979 Argosy 30
WBCCI 10103
Old 05-03-2008, 04:14 PM   #5
eubank
Lynn
Commercial Vendor
eubank's Avatar
Profile:  1967 30' Sovereign
Angel Fire , New Mexico
They're pretty standard little motors. I replaced ours a couple of years ago with on that I purchased online from Mark's RV parts.
The bearings are just bronze sleeves, if I recall. Could probably be replaced by a good electric motor shop, but the savings would not be much (if at all) over just buying a new motor, in this case.
Lynn
WBCCI 21043
Lynn's blogsite: http://forum.aardvarkrv.com/blog/
If you're WBCCI, come visit us at the park (and get more cool air and less oxygen and ... a 50% discount!)
Old 05-03-2008, 05:15 PM   #6
Larry71
Larry71's Avatar
Profile:  1971 23' Safari
Allentown , New Jersey
I had a similar problem with my heater making some loud noises. This was a new replacement, only a few years old. I took it to the repair shop and when they pulled it out they found a huge hornets nest built around the fan blades. This caused the heater to make all the noises. When the nest was removed the problem went away. Worth taking a look at.
Larry
1971 Safari
2005 Nissan Titan
Larry71 is offline   Reply With Quote
Old 05-03-2008, 05:26 PM   #7
Lumatic
Lumatic's Avatar
1962 28' Ambassador
Buggs
Larry
I did find a mud daubber nest earlier. Maybe there is still some in there.
Old 05-04-2008, 05:49 PM   #8
Larry71
Larry71's Avatar
If you find that it is a mud dauber nest, you can buy screens to cover the outlets for the heater. I put them on mine and have not had the problem since.
Larry
1971 Safari
2005 Nissan Titan
Old 05-04-2008, 06:05 PM   #9
Lumatic
Lumatic's Avatar
1962 28' Ambassador
Larry
For whatever it is worth Suburban recommends not to put screens on
Old 05-08-2008, 04:53 PM   #10
musketeer
musketeer's Avatar
Profile:  1989 25' Excella
Kimball , Minnesota
Have a motor that works fine
I'm in the process of replacing my 1989 vintage NT30 K furnace with a NT30 SP. My blower works fine but the furnace won't light, so decided to swap it out for a new one. Used motor and other parts are available very reasonably (like free if you come and get it). Also, new furnaces are available very resonably from Palomino. THe price of a new motor is about half of the price of a new furnace.
musketeer is offline   Reply With Quote
Old 05-08-2008, 06:19 PM   #11
Lumatic
Lumatic's Avatar
1962 28' Ambassador
Furnace Parts
My current furnace is a NT30SP will the NT30K motor fit it? and how much? Thanks
Marshall
Old 05-08-2008, 07:34 PM   #12
eubank
Lynn
Commercial Vendor
eubank's Avatar
Marshall
No, I don't think so. I just checked at Mark's RV Supplies:
Part 0231207
Fits: NT30BW-H-M-MA-MD-MP-MPD-S-SP
$114.00
Part 0231166
Fits: NT-25/30 K
$216.00
See the difference in the shafts? (Plus the one for the NT25/30K is a bunch more expensive!)
Course, if you decide to buy a new motor, shop around. Mark's RV Supplies is ok (I've bought from him before), but I wouldn't guarantee the lowest price necessarily.
Lynn
WBCCI 21043
Old 05-26-2008, 09:45 PM   #13
Snowey BC
Profile:  2008 16' International CCD
kitimat , british columbia
Regarding my heater, we have a new 2008 international and of the 6 nights we camped in it we only got the heater to work once?? And oh how nice it would have been to have it work a few other times. Hubby and I have really given some effort to getting it to turn on, please can someone help. We read the manual to no avail (great if you need part number but that isn't the kind of help we need). Both times have been on Sundays and we are far far away from our dealer.
Snowey BC is offline   Reply With Quote
Old 05-26-2008, 09:58 PM   #14
rceptex
rceptex's Avatar
Profile:  1984 34' Excella
Farmington , New Mexico
Images: 13
It could be your thermostat is not making contact correctly or it could be a faulty limit switch. You might take the thermostat off the wall and see if you are getting a connection when you slide it on & off. If not, they are cheap and easy to replace. If the thermostat is good, then the heater will have to be pulled and the limit switch, igniters, and computer board checked. That should be under warrenty with your 2008
rceptex is offline   Reply With Quote
Blower in bathroom? uwe 1970-76 Tradewind 14 03-07-2008 10:40 PM
Replacing Blower for Dash AC Chaplain Kent Classic Motorhomes 38 09-01-2007 11:32 AM
Furnace Vibration and Noise flyfisherman Furnaces, Heaters, Fireplaces & Air Conditioning 3 10-16-2005 08:37 PM
**Furnace Noise** Silvertwinky Furnaces, Heaters, Fireplaces & Air Conditioning 4 10-07-2003 04:42 AM
Dash AC blower motor PeterH-79MH Airstream Motorhome Forums 6 07-15-2003 07:01 AM
test
