Old 11-30-2013, 04:56 PM   #1
2013 Interstate Coach
Furnace and Heating
I turned on furnace for my first time.
I noticed when I set the thermostat I need the LP gas on for it to heat up, otherwise while on shore power and LP gas off it just blows out as a fan (not all the time but I guess when Thermostat triggered it to be on).
Also, when I was driving with LP gas off, it would still turn fan on (again, not all the time) since inverter was on.
Question for those in the know, does the furnace only heat up with LP gas on, i.e. is my unit operating correctly as outline above? It seems easier to have a space heater while on shore line than to bother with LP gas.
Curious what others are doing.
eliasurbina is offline   Reply With Quote
Old 11-30-2013, 05:00 PM   #2
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
It is a propane furnace...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-30-2013, 05:03 PM   #3
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Yes the furnace, hot water heater and stove use propane so it needs to be turned on. Spend some time with the manuals that came with your vehicle.
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 11-30-2013, 05:04 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Everything appears to be copacetic. The furnace heats with propane only, no electric heating element.
I'm camping in mine right now, and so far this weekend the overnight low temps have fallen to 31°F at least once. The furnace was set on 65°F, and I was plenty warm for sleeping. I had one front window cracked open for ventilation, and the bathroom exhaust fan running, but all other windows and vents closed.
I've never used an electric space heater in mine, just the furnace. I don't feel that using propane is a bother, even when on shore power. If I want to cook breakfast on the stove in the morning I need propane anyway, and the propane tank is plenty large enough to last several days running the furnace, water heater, and stove.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-30-2013, 05:23 PM   #5
Ottawa , ON
Protagonist,
Do you prefer to use the refer on electricity or LP? I going to guess that when you camp and 120V is available at no charge to you, you use that.
Old 11-30-2013, 05:32 PM   #6
Old Interstates (2004~2007 or so) had electric/propane fridges. Later models such as mine have electric-only fridges, but they're dual-source 12vDC/120vAC. The only propane-users on most Interstates are a two-burner cooktop, the furnace, the water heater (dual propane/electric), and the built-in Onan generator.
WBCCI #1105
TAC LA-4
Old 11-30-2013, 08:15 PM   #7
Ottawa , ON
Thanks Protag, I didn't know any of that.
Old 12-01-2013, 07:36 AM   #8
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
Originally Posted by Protagonist View Post
Everything appears to be copacetic. ...
Oh, man, what a word! 'Fraid I couldn't get away with using it here, though.
/ˌkoʊpəˈsɛtɪk, -ˈsitɪk/ Show Spelled [koh-puh-set-ik, -see-tik]
adjective Slang. fine; completely satisfactory; OK.
Origin:
1915–20, Americanism; of obscure origin; popular attributions of the word to Louisiana French, Italian, Hebrew, etc., lack supporting evidence
Lynn
WBCCI 21043
Old 12-01-2013, 07:44 AM   #9
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Lynn
I had a friend who used the Hebrew expression "kol b'seder" meaning "everything's in order". If you say that phrase fast enough, it sounds like a candidate for the word copacetic. :-)
Back to our regularly scheduled discussion :-)
Old 12-01-2013, 09:33 AM   #10
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Not sure on the interstate however our hot water heater uses either electric or propane. It operates off of wp seperate switches one for electric the other for propane. Whenever possible we the electric for our ref rig.
urnmor is offline   Reply With Quote
Old 12-01-2013, 11:27 AM   #11
1977 Argosy 24
Milltown , Wisconsin
Lynn
Kojack used it all the time.
ventport is offline   Reply With Quote
