Old 01-03-2018, 09:08 AM   #1
2018 26' Flying Cloud
Hot Springs , Arkansas
Furnace
What temperature setting activates the furnace? We have a 2016 20'. The heat pump is running and maintains a 72 but still feels cold and drafty.
ljsigman is offline   Reply With Quote
Old 01-22-2018, 09:27 PM   #2
Johnnyooo's Avatar
2016 16' Sport
Colrain , Massachusetts
Check your manual ....The heat pump is good for mildly cold temps.The furnace is good when the temps are very cold....The thermostat for the furnace comes on when it's Set to a temp....If the heat pump is on, the furnace may not come on if the temp inside does not go low enough to turn the furnace on...
Johnnyooo is offline   Reply With Quote
Old 01-23-2018, 12:20 AM   #3
CruizinDux's Avatar
Tracktown USA , Oregon
It's a long shot but try rebooting the t-stat. Instructions should be in yor manual.
A couple of times when i turned on the furnace at the t-stat, the furnace would fire...but the ceiling HP would too...and with cool air. A hard boot of the stat fixed that. Very easy
You might also post your ? on the 20' thread.
http://www.airforums.com/forums/f542...ml#post2058572
CruizinDux is offline   Reply With Quote
Old 01-23-2018, 06:28 AM   #4
twbucksr's Avatar
2020 16' Caravel
2020 16' Nest
Fredericksburg , Arkansas
We full time in our 2018 27FB now but had a 2015 22FB for 2 years prior. The thermostat on the wall of our 22FB only ran the furnace. It was an analog thermostat (no numbers) so it was a guess to determine how warm the stat was set to.
twbucksr is offline   Reply With Quote
Old 01-23-2018, 07:21 AM   #5
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
If your set up is like mine and I do have a new AC on my 2012 FC you will need to turn the thermostat to furnace for it to work. As to the Heat Pump in the AS is only effective when the outside temp is in the forties or higher. Anything less then that it cannot convert the outside air to effectively heat the AS.
urnmor is offline   Reply With Quote
Furnace fumes from new furnace rosser7 LP Gas, Piping, Tanks & Regulators 15 06-01-2013 10:17 AM
Modification to Furnace Propane Line winner LP Gas, Piping, Tanks & Regulators 6 06-29-2002 04:54 AM
Furnace won't light /stay lit Don Furnaces, Heaters, Fireplaces & Air Conditioning 9 06-29-2002 04:37 AM
Deactivated Furnace will Furnaces, Heaters, Fireplaces & Air Conditioning 6 06-22-2002 09:19 PM
Furnace problems... Andy R Furnaces, Heaters, Fireplaces & Air Conditioning 3 04-01-2002 09:29 PM
