Old 07-28-2004, 10:35 PM   #1
Frozen
My airconditioner was a sold block of ice in the front of the unit. I let it thaw
out and now it is blowing cold air again. What would cause this?
vrw1 is offline   Reply With Quote
Old 07-28-2004, 10:39 PM   #2
JohnG's Avatar
Is your AC unit also a heat pump?
Just adding my 2 worth
John G
___________________________
1975 31ft Sovereign International
........Rear Bath Double Bed Model
Tow Vehicle:1999 GMC Serria SLE Classic 1500 5.7Ltr
System: Jordon 2020 Ultima Brake Controller
Hook-Up: Equalizing Hitch and Sway Bar
JohnG is offline   Reply With Quote
Old 07-28-2004, 10:43 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Welcome to the forum!
The AC will freeze for a number of reasons.
The coils need to be cleaned, the water will collect and not run off due to the crud that collects on the fins.
The freon in the AC is low. If you have an Armstrong, or duo-therm penguin, they have service ports that allow for a recharge by a home AC contractor.
If you are running the fan on low, in a high humidity environment will cause freeze up. The slower air movement allows for a higher amount of condensation to collect and it does not drain off fast enough, so it freezes.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-28-2004, 10:50 PM   #4
JohnG's Avatar
I thought that he was talking about the condenser freezing up when he said that is was a solid block of ice in front of the unit. If he meant that it was a block of ice inside the trailer where the evapaorator is then all the reasons you posted are correct.
If the unit is also a heat pump and the ice was on the outside in front where the condenser is then it is most likly the soloniod that switches the unit from inside cooloing to inside heating.
That's why I asked if it was a heat pump also. I don't know if they are made for AS but in commerical use they often freeze up like that on the outside when that soloniod sticks or goes bad.
John G
Old 07-29-2004, 07:18 AM   #5
69 Silverback's Avatar
1969 27' Overlander
Firth , Nebraska
freeze up
Let's not forget , a dirty air filter will also cause ice . Have seen it on residential A/C.
Best of luck,
Loren
69 Silverback is offline   Reply With Quote
Old 07-30-2004, 12:59 PM   #6
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
Best of luck,
Loren
Guilty of that one! I have a reusable and I could have sworn I had recently cleaned it but I guess I was wrong. Froze it up a week ago LOL.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
frozen stabilizer jacks silver suz Jacks, Stabilizers, Lifting and Leveling 10 03-24-2004 11:12 PM
Frozen Milk?? FireFighter Refrigerators 4 11-12-2003 06:14 AM
frozen black water dump valve Rick Alston Waste Systems, Tanks & Totes 6 10-28-2003 02:17 PM
frozen pipes kooblekidz Airstream Motorhome Forums 4 01-20-2003 11:56 AM
Contents of holding tank frozen. Dave Emmerich Airstream Motorhome Forums 10 01-12-2003 08:31 PM
