Old 10-21-2019, 05:57 PM   #1
2018 30' Classic
Traverse City , Michigan
Front AC wont come on
Weve had a ton of trouble with the Firefly talking to Alde system. We had to have the control board changed and it took FIVE trips to the dealer before Airstream and Alde together worked out the issue. Were fine with heat, hot water etc, turned on our AC and the front one wont come on. Back is working fine. Any suggestions?
Motorhomes were our choice for 40 years and decided to get rid of the stress and experience more flexibility in travel.
2018 30 Classic
SMKovalchik is offline   Reply With Quote
Old 10-21-2019, 06:12 PM   #2
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
What happens when you turn on the master override for the front a/c?
Old 10-21-2019, 08:09 PM   #3
2018 30' Classic
Terry, tried the Master Override and nothing happened. No response. He Med the breaker and its fine.
2018 30 Classic
Old 10-22-2019, 09:19 AM   #4
2018 30' Classic
Our saga continues. Here’s an update; it’s not only the AC it’s all the power in the outlets with the exception of the bedroom. Breakers showed the one running the converter seemed partially flipped so flipped it back and bingo, converter started running. Decided to flip the breaker for the AC/outlets. It went to off and would not flip back. Talked to our dealer in MI and he agrees it may be a bad breaker. Have a repair person willing to come up to our lot late today so cross your fingers it’s an easy fix.
2018 30 Classic
Old 10-22-2019, 10:19 AM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
Had you had any strange electrical events, lighting or power outages, lately?
Sounds like the trailer got hit with some sort of electrical problem. It is very odd for 2 breakers to have problems do to manufacturing or age issues at the same tme.
2004 Excursion 4x4
Old 10-23-2019, 05:57 AM   #6
2018 30' Classic
Follow up. All is well. We were able to get a mobile repair to come in when we arrived at our destination. Turns out it was a faulty breaker. Sure happy to have both ACs back. It was 93 when we arrived.
Thank you to those that responded.
2018 30 Classic
How come no one has come up with a parking brake for the AS GM Airstream General Repair Forum 82 07-17-2019 05:01 PM
Open House!!! Come one come all!!! wheel interested Photography 248 08-21-2012 09:32 AM
furnace blowers won't come on jimthesailor Furnaces, Heaters, Fireplaces & Air Conditioning 28 01-30-2010 05:12 AM
chat, come one come all! john hd Off Topic Forum 13 01-25-2005 07:51 PM
Front Right Jack Won't Come Down swebster Mechanics Corner - Engines, Transmission & More... 8 01-17-2004 09:03 AM
