02-23-2010, 01:26 PM
1967 26' Overlander
Lancaster
, Kentucky
Frigi King AC
My '67 International Overlander came with a Frigi King AC. Anyone familiar with this brand? How difficult is it to switch out with a newer model? The existing unit is really large and ugly. Thanks.
02-23-2010, 01:31 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Never heard of it. Assuming it has the standard hole size (14" I think) it is a pretty easy change out. Pull off the old one, drop in the new one. Bolt it down, wire it up. I redid the AC in my 68 about a month ago and it was easy even for me. I would grab one of the Carrier low profiles while they are still obtainable- in fact I did. I also recommend the heat strip.
02-23-2010, 01:36 PM
1967 26' Overlander
Lancaster
, Kentucky
Thanks for the quick response.
02-23-2010, 02:05 PM
1967 26' Overlander
Huntsville
, Alabama
Ugly, Fugly, or Rugly?
Originally Posted by 67twinkie
... The existing unit is really large and ugly.
Most RV AC units are rather large. Some people appear to believe ANY air conditioner spoils the look of an Airstream.
Since you took exception to the unit's appearance, be forewarned that most replacement units are large. Since beauty is subjective, you may want to research if, to you, better looking units are available.
Would you mind posting a picture of your present air conditioner?
Tom
02-23-2010, 02:18 PM
Wise Elder
2010 30' Classic
South of the river
Well, in all fairness, nobody puts them on for looks.
02-23-2010, 02:28 PM
1967 24' Tradewind
Greenville
, South Carolina
I have read here on the forums that in 1967 they went thru the roof with two smaller holes and if you were to upgrade to a modern AC you would need to add some bracing and cut the standard 14" square. Mind you I am not to that stage yet but pretty sure that is what I have read. Also, not familiar with the AC that you have. Guess it is possible that yours has already been retrofitted for a 14" opening as is more standard.
02-23-2010, 02:31 PM
1967 26' Overlander
Huntsville
, Alabama
Is there a choice nowadays?
Jammer,
Since you probably did a lot of research before purchasing a current model Airstream, can one purchase an Airstream today WITHOUT an air conditioner?
Tom
02-23-2010, 02:39 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Tom
I can say that the low profile unit I replaced the Dometic dinosaur with looks much better. I am waiting to see if it makes any difference in my mileage. In theory, there should be less wind resistance, but for all I know the air flow was going over the top of the old AC anyway
02-23-2010, 02:43 PM
1967 26' Overlander
Huntsville
, Alabama
I visited your photography page, and missed it
I can say that the low profile unit I replaced the Dometic dinosaur with looks much better...
Rodney,
Would you care to share a picture of your installed unit? It may help 67twinkie with his issue.
Tom
02-23-2010, 02:50 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
here, this may be the best I have at the moment
02-23-2010, 03:03 PM
Airstream - Other
Bosque Farms
, New Mexico
Our 67 had an original Bay Breeze when we bought it, and, of course, it finally died. The BB required just a couple of very small holes through the roof (the largest about 3-4" in diameter). Obviously, we needed the standard 14" hole for the new unit (a low-profile Carrier). And, yes, a good deal of bracing of the new hole is required, for the weight of the new unit rests squarely around the edges of the 14" hole. If you're lucky, though, somebody already added strong bracing when your unit was originally installed.
Would I recommend the job to the unhandy? Probably not, but it's not impossible. Since the old unit came off in pieces, I could take off one part at a time and give each a mighty heave over the side. The most difficult part was getting the new one up onto the roof and positioned. Maria and I did it alone, but it was one major task, probably too much for our miserable physical conditions.
Lynn
ACI Big Red Number 21043
1967 26' Overlander
Huntsville
, Alabama
Put down your coffee cup and
Rodney,
Dude!
There's still light outside as we speak. Go snap a new picture and post it!
Tom
02-23-2010, 03:09 PM
1967 26' Overlander
Huntsville
, Alabama
What a coincidence
Originally Posted by eubank
Our 67 had an original Bay Breeze when we bought it, ...
That's EXACTLY the same unit I have down to every last detail pictured!
Simply incredible.
Tom
02-23-2010, 03:19 PM
Naysayer
1968 24' Tradewind
Russellville
, earth
Rodney,
Dude!
Tom
I moved it into the shed (think concrete floors and roof) to install the tank when it became apparent that the snow and rain were going to make working on it impossible otherwise. BUT I did find one just for you Tom
02-23-2010, 03:26 PM
1967 26' Overlander
Huntsville
, Alabama
You da man
Thanks Rodney - Look for a little karma for your effort.
Tom
