Old 01-03-2009, 11:18 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Free stuff, Suburban NT22A furnace and more
Just replaced my NT22A furnace and all the left overs are up for grabs, all I ask is that you need it, not just want one for a spare.
NT22A furnace, never ran this but the PO said all it needed was a sail switch. Will sell parts of it or whole.
Unobtainium vent adapter and rubber cup. I read something about a recall on this.
Intake/exhaust vent cap rough but usable.
Model, serial number tag, if that's of any use to someone
From new Suburban NT24SP furnace:
New intake, exhaust vent cap, it is stamped stainless steel, not like some of the heaver cast ones.
3 Duct collars, part #050715 and one round vent cover, part # 050733 for models NT-24SP, NT-30SP and NT-34SP
Whats listed is all I have
You pay the shipping.
Regards
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 01-03-2009, 11:30 PM   #2
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
If you end up giving it away in pieces I need the intake and exhaust cap (the new one would be best) and the duct colars. PO cut the intake pipe up on ours when taking the trailer apart. Would greatly appreciate it if that works out. Very nice of you to offer it up!
I see you're looking for sensors for your water levels. They are basically a stainless bolt and a gasket, I bought mine off ebay for our 69 fresh tank and they are great, just drill a hole, slide them in, tighten and connect the wire on. Here's vendor on there that has them for $3.50 each.
http://cgi.ebay.com/ebaymotors/RV-Ho...Q5fAccessories
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 01-03-2009, 11:54 PM   #3
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
The new intake/exhaust vent and new collars are spoken for.
Bruce,
Old 01-13-2009, 04:05 PM   #4
1973 31' Sovereign
do you still have furnace?
the furnace in my 1973 31ft. Sovereign does not work and I have been told it is not repairable. Would this furnace fit my Airstream and do you have any idea the cost of the sail switch part that you thought was bad?
AustinAir is offline   Reply With Quote
Old 01-13-2009, 05:51 PM   #5
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
The NT22a was installed in a shorter trailer and may not have the BTUs. More importantly there was a recall on this furnace because of deterioration in the crossover tube. It can pump carbon monoxide into the trailer, not a good thing. You also will have a difficult time getting parts or anyone willing to work on it. If this has not disuaded you there is an outfit in Elkhart Indiana that specializes in new old stock, but I forget it's name.
Old 01-14-2009, 09:40 AM   #6
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Lumatic is right this would be undersized for you trailer besides is 34 years old. I was told by the PO the sail switch didn't work but there could be more wrong with it.
I have no idea if this will fit your trailer although the Suburban owners manual shows all the furnaces NT-20A through NT-42T being the same size and sharing most internal parts. You may be able to use my furnace for parts to fix your furnace.
A more appropriate furnace would be the Suburban NT30SP or NT34SP these can be had from Palomino parts: 800-297-5830, my NT24SP was $287.00 so I would think a slightly larger one shouldn't be much more.
Check out this thread on how I changed mine http://www.airforums.com/forums/f427...4sp-47264.html
If you still want it you can have it for the grand total of $00.00 plus shipping.
Bruce,
Old 01-14-2009, 11:05 AM   #7
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Parts needed:
Magic Chef, oven door handle
Do you still need this handle?
Do you have a picture of the oven it goes to?
Do you have a measurement on the bolt set-up that holds it on?
Do you need the entire oven?
Do you need the entire oven door?
Is it a stainless steel door?
Or what color is the porcelain?
I have some extra spare parts.
I may have one... Let me know! Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 01-14-2009, 01:40 PM   #8
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Magic Chef handle
Ed thanks for the offer.
Below is a picture of my stove, the handle is 18" wide and the mounting holes are 14-1/2" apart.
Does not need to be original but would like to find a handle that looks good and covers the old mounting holes.
ID:	73961   Click image for larger version
Name:	Magic Chef 1.jpg
Bruce,
Old 01-14-2009, 02:43 PM   #9
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Bruce, As soon as I can dig out from the overnight snow fall I will check to see what all I have in my parts piles. I think that there may be one out there. Not sure as to what it looks like but I will let you know. Ed
Old 01-14-2009, 05:28 PM   #10
Lumatic's Avatar
1993 34' Excella
Images: 16
I could use a stainless folding burner cover. I have one in OK shape but it has some scratches and pitting. I am looking for one in pristine (or near to) condition. Is that asking too much?
Old 01-14-2009, 08:31 PM   #11
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Lumatic, Sorry, the only extra one of those I had was shipped to Juel over a year ago. Ed
Old 01-15-2009, 04:16 PM   #12
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Ed, I appreciate you taking the trouble to look for this part.
Bruce,
Old 01-19-2009, 10:15 PM   #13
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Bruce, Sorry but all the handles I have left are one solid piece from 66 to 68 trailers. The bolt up measures less than 10" center to center. Ed
Old 01-20-2009, 09:49 PM   #14
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Thanks Ed
Bruce,
Refitting NT22A Suburban furnace oxfletch Furnaces, Heaters, Fireplaces & Air Conditioning 15 11-17-2010 01:36 PM
Replacing NT22A furnace with a NT30SP vhord Furnaces, Heaters, Fireplaces & Air Conditioning 1 02-24-2009 01:00 PM
Furnace stuff... Chuck Furnaces, Heaters, Fireplaces & Air Conditioning 11 12-02-2002 05:36 PM
